Oil Stop Leaks??Do They Work??
Old Jun 26, 2001 | 03:51 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
2:73 GEARS
Rebuilt 700R4, with manual valve body
B&M Megashifter
Soon to be installed
Exhaust Cut-Out and different gears, either 3:73 or 3:42
"There is nothing more addicting than speed"
Old Jun 26, 2001 | 06:35 PM
Vader's Avatar
SURE they work! Except the best ones are marketed under the names "Fel Pro", "National", and "Chicago Rawhide". in other words, the only fix for a leak is a new gasket or seal. Everything else is a band aid that won't last long.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Old Jun 26, 2001 | 09:53 PM
82camaro's Avatar
Car: 82 camaro SC
The only way it can help is if the seal is dry and the additive swells the seal(Hi-tran will do the same thing). But that is usually a temp fix like he said above.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
Old Jun 27, 2001 | 01:40 AM
Guest
Guest
Posts: n/a
LOL@Vader
Wheres it leaking? If its a seal/gasket, I agree... replace it. The stop leaks work for a while, but they dont last. Lucas makes an oil additive that in my experience didnt cause any unreasonable engine wear, and it helped with my leaks... and its not something that swells gaskets. Its still a Band-Aid tho...
Maybe you should go to the grocery store and get a box of Band-Aids?
jklein337
Sep 19, 2018 06:23 PM
TheExaminer
Aug 26, 2015 04:59 PM
Navy8125
Aug 21, 2015 09:32 AM
MY87LT
Aug 17, 2015 08:43 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
