Tach issues
Car: 1984 T/A
Engine: L69
Tach issues
I posted a problem I had with my 84' T/A's tach. Damn thing reads backwards, more like stays peged out when the engine starts. If I turn the car off and then on it goes back to 0 then when I crank it it pegs out. I tried a new tach unit w/no luck. Should only be a signal wire from the tach so I cant see where the issue is?
Car: 1984 T/A
Engine: L69
Originally posted by Vader
There is a tachometer filter/buffer module that may have a problem. They are often on the instrument cluster. Corvettes have them near the distributor. I'm not certain where it might be on an '84.
Thanks for your help.
Car: 4
Engine: 6
Transmission: 5
It's a circuit board on the back of the tach itself. Looks a bit like this.
You need another one.
BTW, the part that's circled, is the factory-trimmed thick-film resistor {insert Flintstones theme here} that changes value, and makes these read high all the time.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
