Is my fan motor dead? NEED HELP WITH THIS *TONIGHT*
Old Jun 26, 2001 | 08:54 PM
AaronRS305's Avatar
For a while now, my fan wont turn on automatically becuase i need to replace the relay, but up until now i could always just turn on my air conditioning and the fan would come on. But now my fan wont turn on when i turn on my A/C, so it is NEVER on, and my car is overheating when i drive around town. I think the fan motor might have gone out, but could it be anything else? I need to get this fixed tonight so try to reply if you can help me.
Old Jun 26, 2001 | 09:11 PM
Enkil's Avatar
It could be the relay.
Try grounding the green wire coming off the fan, that should switch it on.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Old Jun 26, 2001 | 09:33 PM
Stuart Moss's Avatar
I made several recent posts about troubleshooting this very problem. Do a search (use my name or "fan" or...) in this forum and you should see them.
Old Jun 27, 2001 | 01:25 AM
Guest
Guest
Posts: n/a
Fresno... oh joy! Not a good time to be running around without a fan in Fresno! So how is Fresburg?
Anyway... Sounds like the motor died. The connector has a ground and a power lead, its really simple. Take the fan off (another easy job) and hook one end to power, one to ground. Make sure your fingers arent in the way . You can do it on the car too, but its a little harder to get at.
I think the last fan motor I got was about 40 bucks. Its easy to change.
And after re-reading...
The AC wont turn the fan on with a bad relay, the AC has to tell the relay to turn on, just like the fan switch or ecm does. That could be suspect as well.
[This message has been edited by madmax (edited June 26, 2001).]
Old Jun 27, 2001 | 01:13 PM
AaronRS305's Avatar
Well, I took out the fan and tested the motor, and like i thought, it was dead. So i replaced the motor ($30) but when i was putting the motor back on the fan, i broke off a couple of these little things that hook the fan blades part onto the motor. Now i have to go find another fan somewhere that will fit this motor i have.
[This message has been edited by AaronRS305 (edited June 27, 2001).]
eightsixseven
Dec 16, 2024 01:50 PM
krisner89
Oct 10, 2015 06:03 AM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
Bradsaundry
Aug 12, 2015 12:34 AM
Leggman1
Aug 6, 2015 04:15 AM
