Do you need a new speedometer gear when switching from 3.23 to 3.27 gears??
Subscribe
Jun 27, 2001 | 01:03 PM
My friend's rear end with a 3.23 gear just broke. I have a 3.27 rear that I am selling to him. He has an 85 IROC Camaro with the 16" rims. Will he need to switch speedometer gears? Or will it not be off by that much. Thanks in advance.
Reply 0
Jun 27, 2001 | 01:04 PM
Probably not, it should be plenty close enough.
ICON Motorsports
Reply 0
Jun 27, 2001 | 02:07 PM
X84,
There is a 1.2% difference in the gear ratios. At 60 MPH the indicated difference in the speedometer would be 0.74 mph less with the 3.27:1 gearing. this si sroughly the equivalent of the difference created when new tires wear down to the point of replacement. The diameter change is more significant than the differences in your gearing. If you really want it to be dead-accurate, get tires that are ¼" larger in diameter.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Reply 0
Jun 27, 2001 | 04:38 PM
Don't even worry about it, its not enough to make a difference.
Reply 0
Jun 27, 2001 | 04:49 PM
I thought the factory only had a very limited combination of drive/driven gears anyway, and thus 3.23 and 3.27 cars have the same set as you can't match it any closer. Same w/ 3.42 vs 3.45s. I could be wrong though, i've never really looked at the speedo gear selections.
...ed
Ed Maher - Moderator @ The Carb Board
92 Z28 Convertible - Quasar blue / Tan top
LB9 4L60 GU2 G80 - stock, soon to be sleeper
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
Reply 0
Jun 27, 2001 | 06:40 PM
Ed, you are right. The difference is smaller than the smallest change you can make with a speedo gear change.
Do as Vader said and get one size larger tires.
Reply 0
Subscribe
