Stupid Hood Strut Question
Old Jun 27, 2001 | 01:48 PM
350iroc-z's Avatar
Like almost all thirdgens, my damn hood struts are shot. I replaced the hatch struts with no problems. I am looking to replace the hood struts but at a quick glance I could not tell how to take the struts off of the hood. I know this has to be the easiest thing that I am overlooking but can someone throw me bone please.
Ryan
www.350iroc-z.com
Old Jun 27, 2001 | 01:59 PM
Vader's Avatar
350,
There are clips at either end of the strut units. Remove the clips, have an assistant hold the hood (you can't use props very effectively since the hood will have to be moved while you replace the unit) and remove the dead gas spring. Unpackage the new gas spring and have your assistant move the hood to the appropriate position while you install the unit.
Same for the other side - lather, rinse, repeat...
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
[This message has been edited by Vader (edited June 27, 2001).]
Old Jun 27, 2001 | 03:48 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
Transmission: 700-R4
Axle/Gears: 2.73 G80
i used a prop to replace mine and it took all of 10 mintues
86 Z28:
350 vette
aluminum heads
T-5
235/60R15 BFgoodriches
dual 3"flowmaster exhaust
20% tint
hatch wing
2 12"kicker solos
300 watt Sony xplod amp
Sony xplod deck
K&N air filter
Old Jun 27, 2001 | 04:09 PM
One Eyed Jack's Avatar
Where can I get a pair and how much money?
I need some as well.
Old Jun 27, 2001 | 04:35 PM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
Autozone has em. I think you should expect to spend like 25 or so but that number may be low so dont quote me.
Old Jun 27, 2001 | 04:44 PM
86ZRICHIE's Avatar
got mine for 20 each, 30 each for the rear struts
Old Jun 27, 2001 | 08:53 PM
West Coast GTA Man's Avatar
Car: 1989 Pontiac GTA Hardtop.
Engine: ZZ4 - 350
Transmission: Garbage
I got mine at discount auto. $15 dollars for the front, and $35 dollars for the rear. It took me about 10 minutes, with the hood propped up with a broom handle. But like Vader said, try to get someone to help you with holding the hood. It will be a little easier.
Later
Mike
(Gran Turismo Americano) "The Ultimate Firebird"
Smokin 1989 GTA- Bone stock except for exhaust. (no catalytic-stainless pipe into Flowmaster 2 chamber).
Frozer!!!
Jan 19, 2024 04:55 PM
Cleotiz
Jan 6, 2018 08:56 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
