bad off the line, will not burnout PLEASE HELP
Old Feb 13, 2005 | 02:02 PM
har0xz's Avatar
Car: 1986 Pontiac Trans Am
Transmission: TH-700R4
car is a 1986 trans am, 305 tpi. has a aftermarket cam, bigger injectors, was built for a paxton supercharger which is not on the engine anymore.
when i floor the car, it slowly picks up then at about 5-10 mph it will pick up fast. it will not spin tires at all. at idle it runs choppy, im not sure if thats the cam doing it or not. it shakes at idle also. i replaced the plugs 2 months ago, the wires look new, accell supercoil is new.
wierd part is, i guessed the tps voltage before, and it burned out fine and was fine off the line. after i fixed the iac and set the tps to fac specs with a code scanner, it will no longer burnout. the tires will both spin, but it wont go above 2000RPM and it will just sit there and spin slowly. im thinking either a missfire or a bad sensor, but im not sure where to start.
one more thing, when i floor it from a moving start (about 10-15mph) it will pick up fine and launch the car.
Old Feb 13, 2005 | 07:29 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
How much vacuum are you pulling in at idle? How big is the cam. Most cams with a bigger then stock profile will "shake" a little unless you have a really dead on tune. Even then, it can't be helped if you go too big. Thats really weird, I have the opposite problem, my car spins all of 1st and into second, I have never once been able to hook up. But after that, its real slow, lol. Hope you get it all figured out!
Will
Old Feb 13, 2005 | 08:06 PM
badazta87's Avatar
Car: 87 GTA
Engine: Under Construction
Axle/Gears: 3.70:1
yep sounds like a vacume problem to me too. When i was a newbee to the TPI motor i tore it down to a cam and intake on it. Well when i was finshed it did the exact same thing as yours. It took me a copple of hours to fiqure what i did wrong, turned out to be i hooked the breather hose to the wrong port on the throttle body. lol it ran like sh*t. oh well lesson learned.
Old Feb 14, 2005 | 11:37 AM
har0xz's Avatar
i was thinking it was a vacuum problem. where should i start to check for leaks? i found one leak when i first got the car, it was on the left side of the tpi, right under the TPS sensor. there are 3 places that looks like a vacuum hose should be connected. the first is capped off, because i have no emissions stuff. the other 2 are still open, but i dont feel any air sucking through them. should they still be capped?
also: when i put it from park to drive, it likes to rev down to about 200RPM sometimes, then jumps back up. sometimes it will just stall
Old Feb 14, 2005 | 02:29 PM
badazta87's Avatar
Car: 87 GTA
Axle/Gears: 3.70:1
I would start off by buying a can of brake cleaner. Start up your engine and spray all around the vacum lines, and intake gaskets. If the motor revs up when you are spraying the cleaner thats a leak.
Old Feb 14, 2005 | 03:37 PM
jackballs529's Avatar
Car: 1987 Iroc-z
Engine: 355/Edelbrkhds/lpe219cam/MiniRam/
Transmission: 700R4/3.27 9bolt
You can't have those inlets on your TB open. The top one goes to a breather on your passenger side valve cover. I would suggest hooking it back up that way. The secound inlet is for smog, cap it if you are not running smog stuff.
Old Feb 14, 2005 | 08:45 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Sounds like it might be timing related, either its a tad quick or to slow. Advance the timing and see if the idle smooths out. Some people will keep it a tad retared so its sounds rumpity. You may also want to look into what type of cam you have, some SC cams are ground to run good only under boost but usually not to the point where idle is effected since there isnt usually boost @ idle.
Old Feb 15, 2005 | 01:46 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
My 88' IROC TPI throttle body has two ports on the TPS side and one underneath.
Side ports:
Top - to passenger side valve cover.
Bottom - to gas vapor recirculation canister; it affects gas mileage, how much I don't know.
Underneath:
To EGR Solenoid, and valve on vacuum line to bottom side port.
Old Feb 16, 2005 | 11:43 AM
har0xz's Avatar
i checked for vacuum leaks yesterday, couldnt find any. for the first open spot on side of the tpi, im not sure where on the passenger valve cover to hook it up to. i have a breather oil cap, and it connects from the pass side valve cover, to the driver side. i capped it off for now. on the second open spot i hooked up one of the vacuum lines to it. that stopped the leak there, but still same motor problems. i noticed that if im under the hood and i hold the throttle open, the rpms increase without me moving it. i will hold it steady at about 2000 rpm, then it will increase on its own. i tried unplugging the tps, and it still did this. the engine visibly shakes at idle in drive (700rpm).
i have no idea what kind of cam it has, the guy never told me anything about it. all that i know is it was built for the paxton supercharger setup.
Old Feb 16, 2005 | 01:54 PM
har0xz's Avatar
well i think i made some progress. i found 2 vacuum leaks. one was under the tpi, a red plastic hose that was broken. i capped that off. the other one was directly under the iac. same kind of red hose, one part was just cut and the other one was plugged into the bottom of the throttle body where the intake connects. this stopped my shaking at idle, and its raining out so i cant really test the hesitiation off the line. i will update later when its dry out.
Old Feb 17, 2005 | 01:31 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Guaranteed your car will run much better now. Should all but eliminate that off-idle issue. Probably got rid of your "park-drive stall/RPM dive". The RPMs should drop a few hundred RPM when going into drive, but it shouldn't go below 500RPM or so.
Old Feb 17, 2005 | 12:59 PM
har0xz's Avatar
yea the car runs better, still slow off the line though and will not burnout. the shaking at idle is alot better, but still happens sometimes. any other places i should start to look for more problems? btw, thanks for all the help so far.
Old Feb 17, 2005 | 01:55 PM
Car: 1987 Iroc-z
Dirty IAC or mis-adjusted TPS?
Old Feb 18, 2005 | 12:39 AM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
I had shaking at idle, wasn't the engine though, it was the motor mounts, installed energy suspension Polys, and the shakes were gone.
AussiePr0nCar
Mar 6, 2020 04:04 PM
mike_c
Aug 27, 2015 04:32 PM
GVMV
Aug 16, 2015 08:01 PM
novaderrik
Aug 10, 2015 12:44 PM
