oil leak????
Old Feb 13, 2005 | 05:23 PM
3rd gen V8's Avatar
Car: 1992 camaro rs T-top
Engine: 305 ci V8 TBI
oil leak????
I want to know if any one else has had this problem before well on day i changed the valve covers on my 1992 camaro rs for those new chrome ones and omg its not worth it first of all you cant even see the valve covers because of all the air system lines and hoses and secnod of all its a B**** to get them on. Any way to my problem i was on day driving and was doing about 80mph on the high way and i saw a BIG LONG WHITE CLOUD OF SMOKE and i freaked out and pulled over. I oped the hood and found drops of oil all over my new chrome valve covers only on the passenger side and did not see a leak anywhere!
what the hell is going on? and oh the big a** cloud of smoke was form my Whole (cat) being soked with oil.
Old Feb 13, 2005 | 05:35 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
I'm going to take a wild guess and say:
- is it your valve cover gasket?
- is it your breather/PCV?
- is it your intake manifold gasket? (doubtful)
Old Feb 13, 2005 | 05:38 PM
3rd gen V8's Avatar
well i just cheaked all of those things and nothing and i think it only hapens at higher rpm's
Old Feb 15, 2005 | 02:39 PM
dj haf's Avatar
Car: 1990 IROC-Z
Engine: 350 L98
check your valve cover gasket again. it's probably leaking from the back. dont just look at it though, get a white paper towel and rub it on the back where your valve cover gasket meets the head. u might want to check to see if there's oil around the distributor or on the back of the block where the intake sits on the block... there's many places where it could leak but it looks like it's most likely your valve cover gasket. check it out (again if you have to).
Old Feb 15, 2005 | 04:13 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Since the covers are a pain to get on and off without disturbing the gasket, I suspect the gasket slipped.
Old Feb 16, 2005 | 07:19 AM
3rd gen V8's Avatar
ahh man im kinda hopeing that its not the gaskit but ill cheak it agian today and let you guys know if it is.
Old Feb 16, 2005 | 08:38 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If the oil is ON TOP OF the valve covers, it's probably not from the gasket. Oil on headers/manifolds however could easily be from there.
If these are typical aftermarket valve covers, they have no baffle under the breather holes. Those stupid breathers you have to use, always spew oil out at higher RPMs.
Just one more reason not to spend money on such things as chrome valve covers; it's just using your own money as the weapon to shoot yourself in the shorts. They NEVER EVER fit or work right.
"Chrome don't bring the money home".
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
bamaboy0323
Sep 12, 2015 07:14 PM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
