turn signals.....why don't they work?
Old Feb 10, 2005 | 02:51 PM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
Why? I've asked before but got no responses. I've searched but found no results.
Also, would the side marker lights not working have anything to do with that as well? Cuz none of them work, even when the hazards are on.
Thanks.
Old Feb 10, 2005 | 03:30 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Fuse, bulb, or short in the circuit. I know for a fact the reverse lights, if one gets grounded it will blow the blinker fuse when you turn the blinker on.
Old Feb 12, 2005 | 02:18 AM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Yeah...gotta have all the bulbs in working order first.
Old Feb 12, 2005 | 02:27 AM
GTAfanatic's Avatar
Car: 1988 GTA Black notchback
Engine: 1991 L98 355 TWIN Superchagred
Transmission: 700r4 shift kit 2500 stall
Axle/Gears: www.cardomain.com/id/gtafanatic
cheak the flasher one loacted on lower right side of coll and other on the left side
Old Feb 12, 2005 | 02:47 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
blinker fluid.
Old Feb 12, 2005 | 03:15 AM
DeLorean247's Avatar
Car: 1982 Pontiac T/A
Engine: 350 Carb
Transmission: TH200c
YA , It needs all the bulbs the front markers flash as well.
Old Feb 14, 2005 | 09:28 AM
Car: 1994 Trans Am
The blinker fuse is underneath the steering wheel area right? Well all of the fuses look good. Will a short or something blow the bulbs as well, if that's the case?
But why would the hazards work?
Old Feb 14, 2005 | 10:16 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
If all the bulbs are good, and the flasher module is good, then you prolly are in need of a new switch.
What exactly are they doing? Do the lights come on, but just don't blink?
Old Feb 16, 2005 | 09:13 AM
Car: 1994 Trans Am
Well only "1" side marker works. All the rest aren't lit. I didn't check to see if it blinked when I put the turn signals on, but I'm assuming it won't. Only with the hazards on, I'm sure.
But here's my next question, does the turn signal need all the bulbs to work on either side to work, in order to indicate/blink/click/whathaveyou?
-Or does it function like the hazards, not need all lights working?
Spyder_TheGamer
Dec 25, 2015 05:07 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
