Combination questions
Car: 92 Camaro RS
Engine: 350 Modified
Axle/Gears: Stock
I switched my car from TBI to carb and removed the computer, my first question is doesn anyone know how to adjust the TV or kickdown cable with an edelbrock carb? and my 2nd question, if I remove the computer am I suppose to wire the torque converter to lockup? Im not sure, after putting on the carbe and new intake I cant seem to make it shift right at all.
Transmission: 4L80E/4L80E
Getting the TV cable geometry correct is critical. Go to the Tranny forum and search there. In fact, don't drive the car until you get it right.
Same for the TCC lock-up. The info is available on the Tranny forum (as well as tech articles linked on the thirdgen.org homepage).
Hawk312
Aug 22, 2017 08:55 PM
IMissMy86TA
Aug 31, 2015 08:40 PM
