Engine Stress?
Old Feb 18, 2005 | 08:38 PM
Cali Z's Avatar
Engine Stress?
Hey, I just have a question about how stock engines fair up with the wear and tear of everyday driving. I recently got an 85 camaro with a rebuilt stock l98 engine swap, and the engine has about 10k on it along with the rebuilt 700r4 (needs a few adjustments). I use it for daily driving most days out of the week, and usually about 10-18 miles per day. The car itself has 142k, and it seems to be running well like a rebuilt motor. (no smoke, no leaks, runs strong, etc). I keep it maintained the best I can doing upkeep because it is driven most days. The weather is mild for the winter, and the summer is quite hot. I mounted a switch for the fan in case the temps get too high in the summer so i can keep it at normal temps.The most I've shifted at is about 5000(tach is probably off), but that's rarely that I run it like that. It seems to be getting about 16-18 mpg on a mix of city/freeway from what I can tell by quick referencing in my head. My question is this too much stress for this engine? Is it causing a lot of wear and tear by it's design by default? How long should this engine run for in this condition of driving? I've never taken it to the track, and I plan on taking it just once to see how it does. I hope I'm not exhuasting it too much. Any opinions?
Attached Thumbnails Engine Stress?-c-documents-settings-robbie.office
Old Feb 18, 2005 | 09:28 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Almost all engine wear occurs during startup, so limit that and change the oil every 3000 miles and do a tune every 20-30,000 and it will last pretty much forever.
Old Feb 19, 2005 | 12:04 PM
Cali Z's Avatar
ok, so when i start the car, should I let it idle to warm up, or is it okay to hold it at around 1500 or so to make it warm up quicker? Does it make a difference in stress?
thanks for the help.
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
