305 to a 383
305 to a 383
OK correct me if I'm wrong, but if I pull my LG4 and bore it .060 that will make it a 350, right? Then if I drop in a crank from a 400ci engine that will make it a 383.
[This message has been edited by 85rollin (edited July 02, 2001).]
Car: 4
Engine: 6
Transmission: 5
{Insert obnoxious buzzer sound here}
The 305 bore is 3.736, the 350 bore is 4.000. There's no way you can bore a 305 over ¼". It's risky enough to try to take one .060" over, alot won't make it.
If you take a 400 crank and grind its mains down to 350 diameter, then put it in a 350 block, you come up with a 377. Bore the 350 block .030" and that becomes a 383.
ICON Motorsports
ICON Motorsports
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I was wondering how to to that in print.
I want to do it a lot.
Turning down the mains on a 400 crank and installing it into a +.030 305 block makes a 334.
[This message has been edited by Stephen 87 IROC (edited July 02, 2001).]
mhatfield 14
Oct 24, 2015 07:48 AM
