My LG4's finally coming to life!
Old Jun 30, 2001 | 03:21 PM
Golden80's Avatar
When I first got the car the float was set...waaaay off. The car had 80,000 miles on it so I decided to rebuild the carb. Replaced the gaskets, accel pump, MCS, TPS, needle/pin, and the springs. I currently have an assortment of hangers/rods on the way so in about a week it should be running good. After the carbs done then next will be exhaust. And after that I'll install some Tourqer 305 heads and a 262XE cam. Along with that I'm going to install a Holley 600cfm DP and a Performer intake. Should be a decent motor when it's finished. I've decided to build the 305 instead of dropping a 350 because I want to be able to tell people it's an LG4.
(Although in about 5 years I'm going to drop a rat in it. )
Matt
Old Jun 30, 2001 | 11:07 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Go ahead with the Performer, but forget the Holley. Not worth it $'s/HP (you need to replace the distributor, too), and you live in an emissions area. The cam may give you some trouble, but probably not if everything else is in good shape. Since you've already worked the q-jet, it'll give you everything you want out of the Holley and then some.
Otherwise, I think you're on the right track. Obviously, you aren't going to get any objections from me for building a 305...
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
[This message has been edited by five7kid (edited June 30, 2001).]
[This message has been edited by five7kid (edited July 01, 2001).]
Old Jul 1, 2001 | 08:12 AM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
I second that,keep the q-jet.
Old Jul 2, 2001 | 09:14 PM
Golden80's Avatar
With the heads and the cam will I be able to use the stock ECM without any trouble or will I need to get a new chip?
Matt
Old Jul 2, 2001 | 10:30 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Once you ditch the carb or intake, or heads or cam, its technically no longer an "LG4" but for that matter, I put TPI on my LG4 longblock (the cam and heads are still stock LG4) and w/ the cheap mods in the sig, and I can "hang" w/ alot of the stock 350s. However, I will be ditching 305, just thought I would throw my "LG4" story in there.
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
aaron7
Aug 17, 2016 06:02 PM
Polo Z03
Sep 10, 2015 06:43 PM
86White_T/A305
Aug 17, 2015 12:16 AM
kyleb24
Aug 15, 2015 08:24 AM
