ignition problem
Old Jul 2, 2001 | 07:29 PM
custman87T/A's Avatar
ignition problem
I am experencing a strange problem with my ignition, while driving the car began surging so I turned to go home on the way I couldn't hold a steady speed and it would have a hard time idoling. When I got home I figured tune up time so I put new plugs, wires, cap and rotor but still had the same problem. I notice that the power LED on my Crane Hi6s intermitently flashes off when this problem is occuring leading me to believe I am intermitenly losing power in my ignition. What could cause this and what should I look for?
87 T/A 5.0 TPI Auto
Old Jul 2, 2001 | 10:31 PM
Guest
Guest
Posts: n/a
Id check the power and ground to the HI6, if thats not it, try disconnecting it and see if it goes away.
Old Jul 3, 2001 | 05:48 AM
I disconected the Hi6s and the problem is still there. Checked the power and ground wires everything seems ok.This is confusing the hell out of me.
Old Jul 3, 2001 | 02:23 PM
Found out through trial and error that problem was the new crane coil sent with the Hi6s it lasted about two days and crapped out. Time to return it for a replacement.
Infested
May 22, 2018 11:56 PM
mddaniel
Sep 8, 2015 05:16 PM
Bryan F
Aug 27, 2015 07:28 AM
Bryan F
Aug 18, 2015 02:28 PM
