engine rebuild...
Old Jul 3, 2001 | 02:44 AM
soulblade's Avatar
engine rebuild...
I am not looking to go through the hassle of changing from a v.6 to v8 but I am looking for some more horsepower... I am rebuilding the eninge soon and I was wondering if there was a couple of things you guys might suggest on the engine rebuild to me to give me a little more pick up... also some v6 mods such as filters, cold-air, ignition components etc...
thanks
Raymond
Old Jul 3, 2001 | 08:07 AM
El Guapo's Avatar
Guessing you have the 2.8. Instead of rebuilding the 2.8, why dont you look into a 3.4? The 3.4 will slip right in and give some more toque and HP. You should be able to get one from a U-Pull-It for not too much. Then, on a 3.4, you will get more power from your mods than a 2.8.
The 2.8 is a good motor for a V6, I had one. However, anytime you have a good reason (Excuse) for getting a bigger motor, why not do it?
Clayton
Old Jul 3, 2001 | 08:25 PM
Guest
Guest
Posts: n/a
Doing a good job of porting the heads, picking a decent but mild cam, and raising the compression some will help out. Using a 3.4 is a good option.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
hokis
Aug 9, 2015 03:57 PM
