Is a 92 T-5 transmission different, and did they ever put TPI motors in an RS??
Old Jul 2, 2001 | 08:17 PM
CamaroX84's Avatar
Well, we just picked up a 92 Camaro RS. It has a 305 TPI motor and a T-5 manual trans. The clutch is really bad. When I looked in the Summit catalog, it says 82-91 Camaro/Firebird for a clutch kit. Is the 92 version different? Where can I get a reasonable clutch kit for a 92? Also, was the 25th Anniversary Camaro the only time they put TPI motors in RS Camaros? The car does have an "F" for the 8th VIN digit. I thought they were all V6s or TBI V8s. Any
help would be greatly appreciated. Thanks.
1984 Camaro Sport Coupe - 73K Miles, Rebuilt 355 TPI L98, Crane 2032 CompuCam - 214/220 @ .050", Crane adjustable fuel pressure regulator, MSD Blaster coil, custom burned PROM, stock TPI intake, Accel 24# injectors, gutted air box with K&N filters
F41 Suspension Package, 700R4 Tranny, TCI Breakaway torque converter, 3.27 Disc Brake Posi Rear
Hooker Shorty Headers, Catco High-Flow 3" Cat, Flowmaster 3" American Thunder Cat-Back
New Paint
Best 1/4 Mile Run (with old LG4 motor):
16.760 @ 80.74 MPH
Coming Soon:
Aluminum Drive Shaft
[This message has been edited by CamaroX84 (edited July 02, 2001).]
Old Jul 2, 2001 | 08:30 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
92 is not different. I'd recommend a Centerforce Dual Friction; I'm on my second one of them in my 83, I'd have to say it's the best clutch I've ever had for a stock application. It's silky smooth in bumper-to-bumper traffic, yet when it's time to go it hooks up like a piece of metal. Don't buy a clutch (or any other car parts or service for that matter) based on the low bid, you'll be disappointed for sure. Buy the cheapest thing you can find, you'll end up with.... the cheapest thing you can find, just like anything else. You'll hate it until the minute you finally yank it out and throw it in the trash.
They never put a TPI motor in an RS, except for the B4C police cars. You might have run across one of those, which is pretty cool. Or, somebody may have put one in there, like your 84. Check the motor's VIN digit. If you have the build sheet, look for RPO B4C.
ICON Motorsports
Old Jul 2, 2001 | 08:55 PM
CamaroX84's Avatar
Just checked the codes, and it does say B4C. So what does this mean? Thanks for the help.
New Paint
16.760 @ 80.74 MPH
Coming Soon:
Old Jul 2, 2001 | 09:24 PM
Andy89RS's Avatar
B4C is the option code for the police model. Essentially it's a Z28 with an RS's body. I think they were all 305 T-5s. It also means you are the lucky owner of a very desirable thirdgen.
Old Jul 2, 2001 | 09:50 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
What you have is an old cop car. Several states bought those as highway interceptor-type vehicles. Wisconsin, California, Texas, and a handful of others used to have them. A few loacl police depts also ordered them, but most of them were state property. It probably also has 12" front brakes, the same as the 1LE option. Measure the rotors. They'll be either 10½" or 12". People pay a surprising amount of money to duplicate that system.
ICON Motorsports
Old Jul 2, 2001 | 09:55 PM
Vader's Avatar
<font face="Verdana, Arial" size="2">Originally posted by CamaroX84:
</font>
Rockenbach trade-in? They've had some pretty nifty cars go through there...
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Old Jul 2, 2001 | 10:25 PM
CamaroX84's Avatar
Nope, not from Rockenbach. It was from Sherman Dodge in Skokie. Do you live by Rockenbach Vader? I am very close to the dealership. So even though it's red and looks completely like a regular RS, it was still a police car? Was it possible for someone to order the B4C package? The car has 112,000 miles on it and it needs paint bad and the front fascia is really beat up and torn. It runs good other than a bad clutch. We paid $1300 for it? Is this a good deal? Thanks for all the help.
Old Jul 2, 2001 | 10:35 PM
Ovrclck350's Avatar
Buy it off ya for $2500.
Old Jul 2, 2001 | 10:55 PM
CamaroX84's Avatar
In the tech section, it says that the 1LE police Camaros have a "special axle ratio." I think mine is a 1LE too because it has the 145 speedometer, 16" aluminum rims, and 4 wheel disk brakes. I'll check the RPO codes tomorrow (too tired to right now). What is the "special axle ratio"? Also, what is the HP of the motor? Is it 205 or 230? It lists both those figures in the tech data for a 305 TPI with a T-5, but I'm not sure. Thanks for all the help guys.
Old Jul 3, 2001 | 09:30 AM
CamaroX84's Avatar
Just checked, it's a 1LE. Does this mean anything for performance? Thanks.
Old Jul 3, 2001 | 09:32 AM
Ovrclck350's Avatar
Buy it off ya for 3500....
Old Jul 3, 2001 | 01:54 PM
irocbsa's Avatar
Do a search for "1LE." You should find all the upgraded stuff there. Things off the top of my head are: Superior brakes (very desirable), special fuel tank baffling.......
X84, they probably just repainted the car after it was released from service. Look on the roof and you may be able to see four small dimples about four inches from each window. This is where the holes for the light bars used to be. They fill them in after the take all the cop stuff off.
bsa
"If they do not run, Then they will die." - Stonewall Jackson
'87 IROC, 355 TPI, Converted to SD, 700R4, B&M Megashifter, 3.42, Trick Flow Twisted Wedge Heads, Edelbrock Intake, Accel Runners, Comp Cam, Crane Gold rockers, Lucas 24# injectors, Edelbrock headers, Flowmaster 3'' exhaust, Mallory Ignition, Transgo Performance Shift Kit, Corvette Servo, 2,000 Stall Torque Converter
Old Jul 3, 2001 | 05:00 PM
RW91B4C's Avatar
They're rated at 230HP. I dont think there is any diff. between a 91 & 92. Get the centerforce dual friction, its the only one that has held up in my car (3 yrs now), I blew up 3 cheaper clutches (dont ask me how a stock 305 would do that, they just fell apart) in it before the dual-friction, its a good clutch. Some B4C cars got the front 1LE brakes, some didnt. mine didnt . B4C was a kinda mix-breed, you can get alot of good options, and its the only way to get AC with 1LE options
91 B4C 305 TPI - SOON TO BE 383
TREMEC 5-SP, STOCK 1-BOLT REAREAND w/342 GEARS, K&N, AIRFOIL
EDELBROCK HEADERS, DUAL CAT TO HOMEMADE Y-PIPE & 3.5" SINGLE PIPE W/ FLOWMASTER, CRANK PULLEY, MSD, FUEL PRESS REG, COWL HOOD, WELD WHEELS
14.1@ 98MPH
OTHER RIDE
67 CAMARO - STREET CAR, BIG BLOCK, PUMP GAS
350TH w/ATI 10", 12-BOLT w/373 GEARS
10.94@124.13 ON MOTOR - ET-STREETs w/MUFFLERS
Old Jul 3, 2001 | 09:59 PM
302GT_killer's Avatar
dear lord a 1LE B4C for $1300-youve stumbled upon one of the rarest thirdgens ever built-also check for G92. i cant believe it-a 1LE was for sale in primo condition here for $20k
Old Jul 3, 2001 | 11:14 PM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
Should have 3.42s I believe, 230 hp... Sweet find, fix it up and it'll be a great thirdgen.
Ray87Z
-Vortec headed 350.
86 IROC w/ a cammed 305 TPI.
Formerly Ray86IROC.
www.inter-scape.com/Ray
Old Jul 4, 2001 | 12:47 AM
Ryan_Alswede's Avatar
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
Hey does anybody make or does anybody sell some of that cop stuff, like those huge front brake rotors??????? or other cool stuff.
jhawkeye
May 25, 2022 06:33 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
