passing emissons with "113s" on a 91 camaro?
Old Feb 22, 2005 | 12:12 AM
355tpipickup's Avatar
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
how do i pass emissions with the 113 vet heads on a 91 tpi camaro motor? anyone know, the motor now has NO egr hookups at all....no egr valve, sensor, no air tubs, air pump, nothing.
Old Feb 22, 2005 | 11:08 AM
Damon's Avatar
Visual check? If so, there's really no way to hide that. You need a shop that will "work with you" to get you through.
Tailpipe sniffer you might be able to get through even without all that stuff on the motor, as long as the CAT is still in good shape and the engine is in good tune and running well otherwise. That would definitely fall under the "try it and see" category.
69 Six Pack
Oct 5, 2015 07:51 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
jbd1969
Aug 17, 2015 07:06 PM
wruiz
Aug 11, 2015 02:59 PM
