help, starter keeps going
Old Feb 22, 2005 | 01:09 AM
Blake's Avatar
Car: 1991 Camaro RS
Engine: 406ci
Transmission: T-56 LT1
sorry to say but this is on my malibu,I hope you guys dont mind. and this is part of a battery relocation to the trunk
ok guys I did all the wiring updates, grounded to the frame before the rear tire(good and solid) thats 2 gauge, have a wire going to the body from batt as well. then one'+' going to starter.
I'm thinking its the starter. the car want to turn over, but I let go of the key hesistantly now, and it keeps cranking, I dotn think it will start because its not getting any spark. the only thing that i can think of that caused this is I hoooked up my monster tach? and ran wire to my distributor, were I'm pretty shure it goes. and also I noticed that when I was tigtening the bolt back onto the starter that the stud moved a little, I dont know if I needed to use two wrenches, one to hold the stud there and the other to thread on tight. and I'm pretty shure i have these put on right, there is a smaller wire thats on the stud first, then I think a washer then the '+' cable.
I had to turn to the back of the car and toss off the power cable
I hope I dont need a new starter because of just that
ps. the starter will eventually die down, and obviously stop itself but when its turning over normally it just keeps going. even when I turn the key to off, and also even if I take the key out,
i've never dealt with a starter problem before but is there a selenoid that shuts the power off that might not be DEACTIVATING?
cheers
blake
Old Feb 23, 2005 | 09:19 PM
Vader's Avatar
If this were on your F-Car, I would guess that the starter solenoid is sticking. If it were, it might be related to the swap, or just coincidental. Either way, you would need to fix this on your F-car before it did some serious damage. On a ThirdGen, it would also be remotely possible (and coincidental) that the ignition switch would be sticking.
However, this is all theoretical, and since this is on a Malibu, and even though they both have the exact same starter and wiring, I really couldn't be allowed to guess.
Sorry.
Old Feb 24, 2005 | 01:02 AM
Blake's Avatar
Car: 1991 Camaro RS
Engine: 406ci
thanks for your response. its essantially the same. seein gas how I have a 3rd gen as well. I think its something wit the starter. because today I wired it up how it used to be, and it still did that. and then I took the brown (ignition switch wire that goes tot he key tumbler) off and wired up a light too it(since I dont have a test light) and when I activated the starter the light glowed, and then shut off as I released the starting position with the key.
where as if i had the starter hooked up, the starter would keep going all by itself , I could even take the key out. the only way tot stop it was to disconnect the battery. bad times LOL
tell me if you agree with me when I think its something with the starter, internally
cheers
blake
Old Feb 25, 2005 | 09:24 PM
Blake's Avatar
Car: 1991 Camaro RS
Engine: 406ci
dont worryabout it guys, it was the selenoid.
cheers
blake
Old Feb 26, 2005 | 08:31 PM
Vader's Avatar
I wasn't worried. I was fairly certain it was the solenoid.
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Jlanz55
Sep 29, 2015 08:55 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
