Corision and Rust under battery
Old Jul 3, 2001 | 09:41 AM
un4givin89's Avatar
I've been tuning up my car since I bought it a few days ago. Yesterday I removed the battery, and noticed alot of corision underneath where the battery sits from I think a leaky coolent tank. The battery looked great, its recently new, so I whipped it clean and wire brushed the ends to get the little build up off of them. Then I wire brushed and sanded everything on the bottom where the battery sits. I vaccumed it all up and then got some heavy duty rustolium black paint and painted it. It hadn't eaten through the metal yet, but was starting. Do you think what I did should helped prevent any further damage and corision? I'm going to replace the coolent tank next.
Old Jul 3, 2001 | 01:56 PM
irocbsa's Avatar
Do the stuff you just mentioned and you should be good to go.
bsa
Old Jul 3, 2001 | 08:32 PM
Guest
Guest
Posts: n/a
There is a plastic tray thats available and it should fit in the battery area, I have seen them for more than a few different sizes of batteries now. At least it will protect the metal.
Old Jul 4, 2001 | 12:04 AM
TRVLIN99's Avatar
This could happen if a battery leaked at some point in the cars life. When I buy a used car, it is one of the places I check for rust. I just did a total rust prevention on my Iroc, and the battery tray got special attention. That tray, brand new, is only about 25-30 bucks, but needs to be welded in. Matt
Old Jul 4, 2001 | 02:20 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
POR-15 is good for that too, it resists the acid in case you ever have a leaky battery again.
Old Jul 4, 2001 | 06:20 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
<font face="Verdana, Arial" size="2">Originally posted by Apeiron:
POR-15 is good for that too, it resists the acid in case you ever have a leaky battery again.</font>
I second the POR-15, It's a kick A** product, My dad used it in the gastank of his 55 chevy and the stuff has held up for 3 years now. Or try some herculiner.
SSC
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
Grant2k
Apr 4, 2016 08:21 AM
Johnoooooo
Sep 22, 2015 08:55 AM
sahlomonic
Sep 20, 2015 07:15 PM
gta892000
Sep 16, 2015 12:37 AM
