help me figure this out please!!!!
Old Feb 23, 2005 | 12:05 AM
fletch21's Avatar
Car: 1990 RS
Engine: 350 crate
Transmission: t-5
ok guys heres my problem. my car isnt running right it backfires and the rpms jump and it just dont run right. i was messing with the distributor and when the bolt is tight it will still move from side to side and i dont think it should do this. now for the rest of the story if you unloosen the bolt the car will run way way better but when u tighten it back up it runs like crap. im just wondering what can be causeing this problem and how i can fix it without spending 3 million dollars any help is greatly appreciated
Old Feb 23, 2005 | 12:39 AM
Whitels1's Avatar
Car: 99 Z28
Engine: ls1
Transmission: A4
Axle/Gears: 3:42
There sould not be a whole lot of movement when its tight.
Old Feb 23, 2005 | 01:06 AM
fletch21's Avatar
Car: 1990 RS
Engine: 350 crate
Transmission: t-5
ya i know theres not supposed to be movement when it is tight but there is and i dont know why it lets it twist when its tight
Old Feb 23, 2005 | 03:47 AM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
pull the distributor out of the car and look at the gear to see if there is any wear. also did this just start to happen.
Old Feb 23, 2005 | 09:15 AM
brutalform's Avatar
Worn distributer shaft?
Old Feb 23, 2005 | 10:43 AM
smokefan's Avatar
no the gear on the shaft. maybe it has something to do with that or maybe the housing is cracked
Old Feb 23, 2005 | 10:59 AM
fletch21's Avatar
Car: 1990 RS
Engine: 350 crate
Transmission: t-5
well thanks for the replies i havent got to check the distibutor gears yet but you could say it just started but it set for about 8 months with me not working on it. i got pissed and just left it cuz i thought it was the spark plugs and when i was putting it on ramps the damn mastercylinder went out on the clutch and i didnt have money to fix it so i just let it set.
Old Feb 23, 2005 | 02:36 PM
brutalform's Avatar
No. I mean if the distributor shaft is worn, even a tad, you will have these problems. The shaft has a very tight clearance. If it can be even slightly felt, its enough to replace.
sheachopper
Jul 31, 2019 11:27 AM
RedLeader289
May 28, 2019 01:47 PM
mrbird
Oct 20, 2015 03:43 AM
aaron7
Sep 30, 2015 09:15 AM
Zell1luk
Sep 29, 2015 10:36 AM
