Summit timing chain?
Old Feb 23, 2005 | 02:54 AM
onebinky's Avatar
Anybody have experience with Summit's cheap timing chain set? $15 for a single non roller adjustable, just seems a bit to cheap to be real. It's part number SUM-G6501.
I have a OEM set that is only 3000 miles old, but was on my dead 305. Would I be better off using that one? The chain doesn't seem to be streched, but I'm kind of leary about reusing something like that. The engine let a rod go, bent 2 others, and bent all 16 valves. During the process it also cracked the block, swiss cheesed the pan, and ballooned the whole side of the pan out. The chain was definately feeling more turning resistance than usual.
Old Feb 23, 2005 | 03:14 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I think I'd go for an OEM-type link set, or a "real" double roller.
Old Feb 23, 2005 | 03:23 PM
92heritageRS's Avatar
Car: 06 Trailblazer SS
Engine: 6.0 LS2
Axle/Gears: 4.10
I have a summit double roller. It seems like a really high quality piece. I have used comp and crane before. With the naked eye it seems to be up there. My thing with the comp chain is the sprocket had multiple key ways but they had no label as to what groove was advanced, retarded, or zero.
Old Feb 23, 2005 | 04:17 PM
Vader's Avatar
If you are installing it for someone else, and want some repeat business, go ahead and use teh roller chain set. If it is going into your own vehicle, avoid it like A.I.D.S., unless you like to have excuses to tear into the engine routinely.
5-7 pretty much covered my opinion. Use an inverted gear chain (a.k.a., "Link Belt", "silent", or factory type chain drive) or large single true-roller like the LT1/4 used.
And just out of general principle, I wouldn't use the potentially damaged chain set from the blown engine either. The risk just isn't worth saving the forty bucks.
Old Feb 23, 2005 | 05:01 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
I would go with a Cloyes true double roller.
Old Feb 23, 2005 | 05:17 PM
laiky's Avatar
i believe that summitt sells a true double roller for around 30 bucks (i have one). If your going to run a double, you need to be sure it doesn't rub the block. It may require grinding (mine did).
Old Feb 23, 2005 | 09:17 PM
onebinky's Avatar
Awesome guys, that puts my mind at ease since that's pretty much along the lines of what I was thinking. I have a few other things I have to send back to summit anyways, I can just toss this in the box with it all.
I'll look into the summit double roller and the cloyes. Thanks for the input guys
Old Feb 23, 2005 | 10:18 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I have the Summit Double Roller on my 383 and on my GF's 350 TPI. No problems the last 15K miles.
Old Feb 24, 2005 | 03:01 PM
Damon's Avatar
Don't confuse the $30 Su6mmit double roller chain with the $15 cheapie. The double roller is a decent piece- still not as good as a Cloyes True Roller, my usual go-to favorite- but it's decent. The $15 chain is junk, just like all $15 chains.
Yes, you may have to do some MINOR grinding on the top of the main oil galley boss above the cam bearing. The double-row gear will clear it, but the double-row chain links may rub on it slightly. This is true for most SBC double row chain sets.
For chains that are not marked clearly as +4* adv, 0* and -4* retarded the usual symbology is:
Triangle = 4* advance
Circle = 0* straight up
Rectangle = 4* retarded
Old Mar 2, 2005 | 04:08 AM
Night rider327's Avatar
Car: 1988 Camaro
The $30 summit double roller is very good IMO. I used them on the last 3 engines I built for me and my dad. 2 on 327's, and 1 on a 350. All 3 engines sees 6000+ rpm use weekly, and 2 (1 327 and 1 350) are daily drivers
The last Cloyes I used was alittle too loose for my liking. Ever since then it's been summit $30 double rollers for me
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
MY87LT
Aug 17, 2015 08:43 AM
