OIL FILTERS.....what sizes
Old Jul 2, 2001 | 06:00 PM
camaro6spd's Avatar
Ok, just got a quick question, do all 350 use the same oil filter from 87-95? I will be buying a block in that year range and I would just like to know what ACDelco Filter to buy, if they do I would like to get the largest filter I can for the break in and after, maybe the truck oil filters are larger. Any one have any ideas or clues?
Old Jul 2, 2001 | 06:11 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes.
PF-25 is the short one the book lists for these cars; PF-35 longer standard construction; PF-35L synthetic element; PF-1218 I forget what the difference from PF-35 is.
ICON Motorsports
Old Jul 2, 2001 | 07:48 PM
Z28DJP1987's Avatar
I have been using a two quart oil filter made
by A/c Delco. It is the long type, but don't have the P/N. Nice to have that extra quart of oil in the engine.
Old Jul 3, 2001 | 05:49 PM
82camaro's Avatar
Car: 82 camaro SC
I 'think' the 1218 has the anti-flow back valve. The PF35 long filter holds about 1 qt. Some companies make a 2 quart filter, but it's really long--truck only.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
Old Jul 3, 2001 | 06:05 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I think 82 may be right about the 1218, it's either that, or a built-in bypass valve... can't recall for sure though
ICON Motorsports
Old Jul 3, 2001 | 08:10 PM
Guest
Guest
Posts: n/a
The 1218 has an anti-drain back valve.
PF932 is the 2 quart filter... Its a bit too long IMO.
Old Jul 3, 2001 | 08:48 PM
Xenodrgn's Avatar
Funny, I just bought one, and the guy said that I needed PF47. Can someone shed the light on the situation?
1985 Camaro SC - 2.8L, auto.
http://www.xenodrgn.f2s.com/Frontright.jpg
Old Jul 3, 2001 | 09:01 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
The PF47 is because you have a V6.
I use the PF1218 on my V8. It holds more oil than the stock PF25 and it does have the drainback valve. The 1218 isn't too long, it is about 2.5" above the bottom of the oil pan.
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
3.73 Posi
4wheel Disc Brakes
Summit 1-5/8" headers, 2.5" Dynomax catback.
Best 1/8: 9.519@72.74
'97 Bonneville SSE
Old Jul 3, 2001 | 09:17 PM
Xenodrgn's Avatar
Ahh, ok, I see.
Next question, is there any hop-up I can use in terms of oil filters and better filtration? (IE more oil capacity, synthetic element, drain-back valves and ect.)
Old Jul 3, 2001 | 09:23 PM
Guest
Guest
Posts: n/a
Did someone say the 1218 was too long?
I think the best filter is the one thats made the best, not the one with the best materials. Fram is a key example of that, good paper, lousy construction. Personally I think synthetic is to take another 5 bucks outa your wallet when you change oil. Anti drain back is probably a good idea. Other than that, pick a good filter and change it regularily.
Old Jul 3, 2001 | 10:43 PM
Intense92's Avatar
Is a filter with a anti-drain back valve really neccessary on a small block chevy, the filter is positioned so that oil will not drain out of it, or does the valve help keep oil in the passage ways of the engine that lead up from the filter, by the way I read an interesting oilfilter study http://members.nbci.com/minimopar/oilfilterstudy.html
It's a MOPAR site but makes good reading.
92 Camaro RS 5.0 5-Speed
L98 Alu. Heads
SLP coated headers
Dynomax cat-back
14" open air cleaner
1998 Dodge Ram SS/T
Old Jul 3, 2001 | 11:13 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
That mopar oil filter page is good reading
Now if we can only find out about what brand name oils are sold under other lables well be set for life.
SSC
The stud formerly know as SUPER-SPORT-CHEVY.
What happend to my password?
Oh well!
Old Jul 5, 2001 | 10:33 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Xeno (and other V6 guys), don't use the PF47! Er, okay, well, you can use it if you want, but there's an alternative.
Find the PF-52. That holds twice as much oil as the PF-47 does. In fact, here's the info on those filters! In '82, GM decided that the 2.5l I-4 and 2.8l V6 should use the PF-47. They spec'd this filter for the V6 until 1988, where they decided the 1988 2.8 should use the PF51! As you know, nothing was changed to the 2.8 between 1987 and 1988. GM continued to spec the PF51 for the 90-92 3.1l engines.
The PF51 had no anti-drainback valve. GM stopped making it, and came out with the PF-52. Use that one. (Actually, "good luck" finding a PF51 on the shelves; they're gone.)
You'll need an extra 1/2 quart of oil, though. This boosts your oil change from 4 quarts to 4.5 quarts. I pre-fill the oil filter (which you should do anyway, to any engine, with any oil-filter) with a 1/2 quart of oil.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Aug 12, 2002 | 03:17 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
what do you guys think of the double and extra guard fram filters? better than standard AC?
Old Aug 12, 2002 | 04:21 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I would not put a Fram oil filter on anything I own. Look at the "minimopar" site link above, where some guy did a real simple oil filter comparo, cut them open and took pictures, measured the amount of filter media, etc.; you wouldn't believe how junky the Fram looks inside.
Stick with the AC or other high-quality brands, which doesn't include Fram.
Ooops, the old link is dead, here'e the new one...
http://www.minimopar.net/oilfilterstudy.html
Old Aug 12, 2002 | 08:59 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
pf-932 from acdelco
here's a pic of it.
it comes about 1/8" above the bottom of the oil pan. now for you guys with the oil cooler, it will be too long. total 6 quarts.
Hotrodboba400
Dec 10, 2019 07:07 PM
Linson
Sep 21, 2015 01:08 PM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
BOOT77
Sep 5, 2015 03:55 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
