Wont start and smoking!
Old Feb 23, 2005 | 07:11 PM
tommy z-28's Avatar
Car: 1985 z-28
Engine: 350ci
Transmission: 700-r4
The car started a 2 days ago and ran fine. I parked it and my little bro a day later tried to start it and it turned over but died. He repetedly tried to start it for about 15mins. He may have flooded it. ANyway, he waited 24hrs till today to restart and it would not catch he said and eventually it started smoking from the engine bay. He said it looked to come from the carb. NOTE: the car may be nearly out of gas.
ANy suggestions? Im going home late tonight to help him out.
He said he did not hold the key over for more than 5-8 seconds at a time.
The fast idle adjustment is a little bit low, but i did start it fine two days ago, just havent had chance to change the setting as I am away from home.
Old Feb 23, 2005 | 09:37 PM
Vader's Avatar
I'm guessing that you will find that it was flooded, that it smoked when it finally started due to the excess fuel, and that it may continue to smoke if there was enough flooding to dilute the oil in the sump. If you detect a fuel odor in the oil, plan on changing it ASAP, or risk severe engine damage. Better yet, it might be a really good time for your li'l bro to practice his routine maintenance skills.
Old Feb 23, 2005 | 11:35 PM
tommy z-28's Avatar
Car: 1985 z-28
Engine: 350ci
Fixed. Wasnt getting any air. Choke was not opening the butterfly. Adjusted and started right up. I guess ill have him check the oil still for a gas smell.
Old Feb 23, 2005 | 11:52 PM
sellmanb's Avatar
Car: '86 Berlinetta
probably fouled your plugs as well, he'll/you'll probably notice a decrease in performance from it.
bryan623
Mar 22, 2021 06:43 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Red iroc-z 305
Sep 30, 2015 05:22 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
86White_T/A305
Aug 17, 2015 12:16 AM
