Engine stalling/dies when moving from park to reverse
Old Jul 4, 2001 | 11:58 AM
1992camaro28's Avatar
Hi All,
I have a 1992 Camaro Z28 with a 5.7 and 41,000 miles on it. The problem I have is that sometimes, when I shift from park to reverse, the car stalls (the rev goes down), and the engine dies. I start it back up and everything is fine again. The engine stalling isue happens about once in every 5 starts.
Another thing I notice is that sometimes this instrument notice light comes on called "INFL REST", and I can't find anything on this in the car manual.
Could it be an O2 sensor or possibly a distributor/pickup coil going bad? That's my theory based on what I've read from other posts.
If anyone could please help I'd really appreciate. It's so embarassing to see it stall when I pull out of a parking lot.
Old Jul 4, 2001 | 12:03 PM
Vader's Avatar
'92,
"INFL REST" is the supplemental inflatable restraint system arming (air bag, or SIR for short). It really is incidental to the engine stalling and shouldn't have any bearing on the problem.
Typically the O2 isn't even active untila a couple of minutes after the engine has been running. I would guess that you have problems with the IAC system, such as a dirty throttle body or sticky IAC stepper motor.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Old Jul 4, 2001 | 01:40 PM
thank you so much for your help! I'll bring this up to the mechanic this week.
best regards and have a great 4th of july
virgo
Old Jul 5, 2001 | 05:19 PM
IROC5.7TPI's Avatar
Clean the throttle body and IAC with 02 sensor safe carb cleaner. It needs to be done once a year for optimal performance.
If it hasn't been done in a while its worth taking the upper plenum and runners off and cleaning the whole thing out.
Mike L.
It ain't pretty.......
1987 IROC Z TPI 350 A4 3.27 Borg-Warner.
Mods: 2300-2500 Stall Converter, Shift Kit(GM parts), TPI Specialties Stage 3 PROM, Modified Airbox w/ K&N's, homemade cold air, Relocated MAT sensor, Gutted MAF, 160* thermostat, Accel 8mm Wires, bypassed TB coolant, Flowmaster 3 chamber single 3" in/out muffler, 3" MAC mandrel intermediate, custom dual !cat Y-pipe. airfoil, ported plenum. !smog
http://www.MichaelLasiuta.home.att.net
**BOYCOTT LAPEER DRAGWAY**
AkDrifted
Aug 17, 2015 07:45 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mizz0313
Aug 12, 2015 06:45 AM
hokis
Aug 9, 2015 03:57 PM
