starting problem
Old Feb 24, 2005 | 09:04 PM
BCdawg57's Avatar
Car: '91 Z28, '13 Civic EX-L
Engine: 355 LT1, 1.8 I4
Transmission: T56, 5spd auto
Axle/Gears: 10 bolt 3.42(as long as no breaky)
starting problem
ok today i went out to start my car and i turned the key and i got this reving noise, like something wasnt engaging, but then i truned the key a second time and the car started up fine. I think it is either the starter or the solenoid.
what do you guys think?
Old Feb 24, 2005 | 09:11 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
sounds like a bad solenoid. I would just get the whole thing. some times the bendix on the starter gets stuck as well (what the solenoid throws out)
Old Feb 24, 2005 | 09:31 PM
BCdawg57's Avatar
By getting the whole thing, you mean go buy a new solenoid and not one of those repair kits? also, that whole bendix getting stuck thing, would replacing the solenoid fix that?
Old Feb 25, 2005 | 12:40 PM
sellmanb's Avatar
Car: '86 Berlinetta
i think he means a whole new starter. Which is what you should do. Take your starter to NAPA, tell them that you want an LT1 starter, give them yours, fork over another 90 bucks or so, and you now have a mini starter that'll spin your engine real fast, and not be prone to heat soaking
Or just go get a stock replacement, whatever works. I think before they charged me for the core, it was like 60 bucks for my stock replacement starter.
Old Feb 25, 2005 | 03:32 PM
BCdawg57's Avatar
would i be able to use the solenoid over again or would i have to buy another one of those also?
also, what is heat soaking?
thanks
Old Feb 26, 2005 | 12:57 PM
sellmanb's Avatar
Car: '86 Berlinetta
The solenoid is attached to your starter. It's really cheaper in the end for you to take the whole starter assembly in and get a new one.
Heat soaking is when your exhaust gets a little too close to your starter, and the resistance in the wires to the starter goes up from the heat, so you cant start the car with the starter until it cools down.
Old Feb 26, 2005 | 01:41 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Heat soaking is the weak factory starter saying "replace me..."
Old Feb 27, 2005 | 01:12 PM
sellmanb's Avatar
Car: '86 Berlinetta
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
