holley 600 or road demon junior 525 or 625
Old Feb 20, 2005 | 12:42 PM
1984z28master's Avatar
Car: 84 z28
Engine: 5.0
Transmission: 700r
hey im about to get a new carb for my 84 305 its got a eldelbrock eps intake on it and im wonderin whether i should get a holley 600cfm or road demon jr. 525cfm or 625cfm. what do u think please help me
Old Feb 24, 2005 | 04:55 PM
Tech @ BG's Avatar
What camshaft are you using?
Old Feb 24, 2005 | 09:33 PM
Car: 84 z28
Engine: 5.0
Transmission: 700r
its just a stock one
Old Feb 24, 2005 | 09:37 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Stock for what 305? The LG4 and the L69 had two different cams.
Old Feb 24, 2005 | 09:55 PM
Car: 84 z28
Engine: 5.0
Transmission: 700r
good question im not really sure i know its a 305, but i dont think its the motor that came in the car. where would the numbers be on it?
Old Feb 24, 2005 | 10:20 PM
camaroracer016's Avatar
Car: 88 Camaro
Engine: 5.3
Transmission: TH350
id bet that it is a lg4. I do beleive that is the most common 305.
Old Feb 25, 2005 | 07:03 AM
Tech @ BG's Avatar
If you're using the stock cam in the engine, a 525 Road Demon should work really well. It will give you better throttle response, acceleration, and drivabilty than a larger carburetor would.
Old Feb 25, 2005 | 01:18 PM
Air_Adam's Avatar
Yes. Also, when in doubt, go small
Old Feb 25, 2005 | 03:46 PM
Car: 84 z28
Engine: 5.0
Transmission: 700r
so do u think a 525cfm road demon jr. manual chock would be good im puttin on and edlebrock performer intake. what u think about that combo?
Old Feb 25, 2005 | 03:52 PM
Tech @ BG's Avatar
It should work very well on a combination like this.
Old Feb 25, 2005 | 08:11 PM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
I just have to ask, why the intake swap?
Are you going to get the performer RPM or the basic performer?
Old Feb 25, 2005 | 10:38 PM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
barry grants carbs are really nice...i would go wit hthe grant over the holley any day.
Old Feb 25, 2005 | 11:51 PM
Car: 84 z28
Engine: 5.0
Transmission: 700r
im changin the intake because i got one from a friend for 75 dollars and its just a basic performer
Old Feb 26, 2005 | 12:29 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
I would never go mechanical choke, but thats just me. I dont like screwing with that, its just not worth it. The electric choke or the conversion is your friend. My holley carb 305 starts everytime on the first crank. It starts way better then any new FI engine. I did the electrical choke conversion and will never regret it.
As for carb i'd go 625 so you will be ready for some upgrades later on.
Old Feb 26, 2005 | 12:30 AM
Car: '85 IROC
Engine: LB9
The performer is supposedly a step down from the EPS, I couldn't say for sure whether there'd be any noticable difference between the two if you're using a stock cam, but if I had a choice between the two, I'd stick with the EPS.
Old Feb 26, 2005 | 12:33 AM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Bert is right the EPS is supposed to be the **** on stock style motors.
Old Feb 26, 2005 | 10:43 AM
Car: 84 z28
Engine: 5.0
Transmission: 700r
where can i get a converison from manual to electric, and i was goin to go with the eps but this was just such a good deal. how many horespower should a these to give me the 525 road demon jr. and edelbrock performer?
Old Feb 26, 2005 | 11:27 AM
Tech @ BG's Avatar
You can order the 525 Road Demon Jr. Carburetor with either an electric, or manual choke.
Old Feb 27, 2005 | 02:14 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
I think the Holley 600 would do just as well if not better than a Demon 525 myself.
But I guess I'm a little biased since I bought what turned out to be "too small" of a Demon carb on my car right now that was "recommended" by a BG/Demon tech rep.....but not the same one posting here...need to make that clear.
And that was after I gave them every spec on my engine they asked for.
Think about it this way - the stock Q-Jet that came on the LG4's flow greater than 700 CFM's so why would you go even smaller than that? Just for better velocity at lower RPM's?? Yeah maybe, but it's not gonna flow as well as the Q-jet up top...
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
TexasMaro
Sep 15, 2015 06:50 PM
makaveli09
Sep 15, 2015 10:43 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
