What does moving the intake centerline of a cam accomplish??
Old Feb 25, 2005 | 09:25 AM
Slow89Iroc-Z's Avatar
Car: 1989 Iroc-Z
Engine: 350ci SBC
What does moving the intake centerline of a cam do to its performance? Say I have the a cam with a 106 intake centerline and I move it to a 109 centerline...how would its perfomance differ?
Old Feb 25, 2005 | 01:13 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
The intake centerline determines where your intake valve closes on the compression stroke. Also known as the IVC ABDC on your spec card. This determines where you'll start to make cylinder pressure. The smaller the ICL number (less crank rotaion), the sooner it will close after BDC, and the larger the number (more crank rotation), the later it will close after BDC. The later you close the intake valve, the more you move your power band upward because you'll be building cylinder pressure later in the compression stroke.
Tom
Old Feb 25, 2005 | 05:20 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Great explanation Tom!
Street Lethal
Apr 30, 2019 12:14 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
AkDrifted
Aug 17, 2015 07:45 PM
