need cam recomendation
Old Feb 26, 2005 | 05:54 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
im looking for a cam that can fit my engine with stock heads, that i can get the most out of, and match up with the holley stealth ram.
Old Feb 26, 2005 | 09:25 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Can't really do that. Assuming you have 083 heads, your max lift/cam selection falls way short of the HSR potential.
I guess what you really want is the largest cam your heads can handle without pulling them and doing work? If so, then most likely in the max .480-.490 lift range.
Whats your plans to pass smog with the HSR?
Old Feb 26, 2005 | 09:58 PM
GTA matt's Avatar
Car: 1990 GTA/1989 Iroc
Engine: L98/383
Transmission: 700r4/t56 magnum
Axle/Gears: 9"
With the stock heads you are somewhat limited. At the very least you will have to change valvesprings and install screw in studs. The stock heads may not even flow enogh to take advantage of a big cam, but with a HSR i would recommend the Lt4 hot cam.
Old Feb 27, 2005 | 12:00 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
thanks.
i do not need to pass smog anymore ever again.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
