Engine dies as soon as I start it...
Old Mar 1, 2005 | 01:38 PM
JerseyMark's Avatar
Car: 1991 RS Convertible
Engine: 96 LT1
Axle/Gears: 3.45 9-Bolt
Hey Everyone,
Ive got a problem I was hoping someone could shed some light on. I hit a curb a pretty hard a couple weeks ago. Hard enough to bend the K-Member. Ever since the accident, the car has a hard time starting. The first time I turn the key, the car starts, but then dies a second after it starts. It will usually do this 2 times. Then, on the third attempt, it starts and stays on. Any ideas?
Thanks,
Mark B
Old Mar 1, 2005 | 01:57 PM
90RS305's Avatar
Car: 96 Silverado/99 Suburban
Engine: 700 cubic inches of 'Muican Awesome
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
How well does the car run after you get it started? Try this, next time your doing a cold start, put the key in the "ON" position and leave it for 5-10 seconds, see if that helps. Also, check your battery connections, make sure they are nice and snug...
Bruce (90RS305)
Old Mar 3, 2005 | 12:14 AM
SDIF's Avatar
Car: 91 Z/28, 89 RS Race Car
Engine: 305 stock / ZZ4 AFR 195 9.7:1
Transmission: T5 / t10 / Jerico
Axle/Gears: 10blt w 3.42, 9 in w /3.80 DL
I bet the wreck damaged your starter.
That is where the main power supply come in off the battery.
The solonoid may have cracked and is giving you an internat short.
I would check the starter solinoid and the wiring down there.
eightsixseven
Dec 16, 2024 01:50 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
