Converting to carb
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Converting to carb
I read the tech article on converting from efi to carb. It looks pretty straight forward however I have a few questions.
Since I'm considering doing this on my truck it's not an f-body but still GM. The tranny is a 4L80E that needs a computer to control it. Did the f-body have a computer controlled tranny after the 700R4 changed designation?
If so then does the carb/ignition conversion affect the ECM's ability to operate the tranny?
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.546
Car: Death Mobile
Engine: 666 c.i.
Steve, the only thing the ECM controls on any F-body auto box is the TCC Lock up.
I assume you want to retain the 4L80E but installing a carb still requires an ECM (or PCM depending on year and engine of the truck). It is feasible to "reprogram" the ECM to handle "just" the tranny portion, but it is beyond the typical "DIY PROM" burner's capability. It requires disassembling the machine code and then "cutting and hacking" the code so only the relevant parts remain. Not something you'd want to try for your "first project" in DIY Programming.
The second possibility is a "stand alone" ECM just for the tranny, like from JET. This is the common solution for guys who want to run a 4L80E in an older vehicle that never came with a 4L80E (or even an ECM).
If the computer only controls the converter lockup then you could theroetically just rip out the entire computer harness. The only thing you'd have to do is wire up a switch for the lockup.
Unless, of course, the computer does more than just lock up the converter, which I'm kind of getting the impression it does since Glenn mentioned the JET unit, then you'll have the buy that.
I did use a 4L60E converter in my 700r4 and had no problems with it though...
1990 GTA
-355 carb'd, nicely reworked '64 vette heads, 2500 stall, 4.10's, other small things.
-Alston SFC's, Eibach Pro-kit, Koni's all around
-100+ nitrous shot
-Cruising in style with leather and nice stereo.
1990 GTA
-100+ nitrous shot
Car: Death Mobile
Engine: 666 c.i.
The ECM controls all aspects of shifting on the "E" versions. The non-E versions are still "manual" but have locking TCC.
While there are E and non-E versions of the 4L60, I believe all 4L80s are E versions.
Steve, check out JET and their stand-alone computer.
Car: 87 IROC L98
Just wondering that's all. I'm aware of the JET computer. The 4L80E needs a computer to operate, not just converter lockup. Theoretically you could make a push button tranny with it. All the shifter does is move an electronic control in the valve body and the computer does all the shifting. Incorporate something like a forumula one shift paddle system on the steering wheel and eliminate all the extra linkage.
The 4L80E is an electronic version of the TH400. About 80% of the parts are the same. As much as I would like to just switch to carb and install a TH400, the OD is a nice feature when you have 4.10 gears.
theshackle
Mar 5, 2017 06:37 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
Dialed_In
Aug 20, 2015 01:45 PM
454ss, 4l80e, article, body, carb, carburated, coneverting, conversion, convert, converting, ecm, engine, iroc, tech, truck
