Label these fuel/vent lines please...
Old Mar 1, 2005 | 07:07 PM
DURTYBIRD's Avatar
Car: '99 HO Z28 / '03 Trailblazer
I'm finishing up my fuel pump swap/hard line install on my TPI conversion. I *think* I know which is which - but I'm not positive....so if you would, please label which is feed/return/vent. The unmarked one goes right to a filter fitting.
Thanks!
Attached Thumbnails Label these fuel/vent lines please...-h-im01fuji-dscf0030.jpg
Old Mar 2, 2005 | 09:07 AM
IceManRS305's Avatar
Car: 91 Camaro RS
Engine: 350 bored .030 carbed
Transmission: t5
Axle/Gears: 3.08
from that picture, since i cant see the OD/ID too well to compare, id guess that A is to your carb/injection system B is your return line, and C is the gas tank vent that goes to the carbon can
Old Mar 2, 2005 | 09:13 AM
DURTYBIRD's Avatar
Well, as it turns out the guy I nabbed the hard lines from for my TPI conversion didn't include the line from the fuel filter back to the hard lines. So I'll have to visit a parts yard soon (when it stops raining ) I should be able to compare at that time.
If it helps, "B" is larger physically that "A" or "C" if I recall correctly.
Thanks!
Old Mar 2, 2005 | 09:22 AM
Car: 91 Camaro RS
Transmission: t5
Axle/Gears: 3.08
B would be your feed then because the return line is smaller than the feed and the vent is smaller than the return.
Old Mar 2, 2005 | 09:23 AM
Car: 91 Camaro RS
Transmission: t5
Axle/Gears: 3.08
ill sent you some pics later on today, i have a carbed system but ill show you how it looks on my car.
Old Mar 2, 2005 | 09:30 AM
DURTYBIRD's Avatar
The lines as pictured are from an LG4 car. I've swapped the in-tank pump but the lines there are still LG4. I should have marked them when taking the old lines out.
...but that's what Thirdgen.org is for, right?
gta892000
Aug 11, 2019 11:16 AM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
mcgarnicle
Sep 24, 2015 07:18 PM
gta892000
Sep 16, 2015 12:37 AM
