6.0 head swap help
Old Mar 3, 2005 | 12:58 PM
davcamaro's Avatar
Car: 1985 IROC
6.0 head swap help
The 6.0 head swap is getting a set of cylinder heads from a 6.0 liter pickup truck, they are aluminum like the LS1 head, but have the same intake and exhaust ports as the LS6 Z06 heads, but you can pick em up for like $300 bucks compared to the LS6 head will cost you around 1200. The drop your compression ratio to 9.3:1 but you can have the heads shaved down to bring the compression back up. My question is where can I go to get this done? I also want to know what the right compression ratio is or how much I should shave them. lastly, does anyone know where I can get these heads?
Old Mar 3, 2005 | 02:00 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Machine shop, preferably a racing one
Depends on alot of things.... if this is a strictly street motor, you'd typically aim for low-mid 10s. Your qualified machine shop will work with you to get them into that range if possible.
Junkyard
Those heads won't fit a third gen, unless it has a LS1 type motor in it.
Old Mar 3, 2005 | 02:13 PM
davcamaro's Avatar
Car: 1985 IROC
I am getting an ls1. what are these heads called? or at least what car/motor are they on so I can how how to find them
thanks
Old Mar 3, 2005 | 02:14 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
They come in trucks.
Old Mar 3, 2005 | 02:20 PM
Crayz9000's Avatar
Car: '86 IROC, '87 Volvo 240, '09 Malibu
Engine: LB9 5.0L
Does LA mean you're in Los Angeles or Louisiana?
If you're in the Los Angeles area, I can recommend a good machine shop in the area that handles a lot of racing orders. He's an expert with GM engines.
Old Mar 3, 2005 | 02:51 PM
davcamaro's Avatar
Car: 1985 IROC
it does stand for Los Angeles, I just fixed it. Actually I am new to LA, so any shops you could suggest would be great, I still don't completely know my way around. do you know of a few good junkyards too, one where I might be able to find these heads fo instance? do you recommend any mechanics( I am looking into an ls1, manual 6 speed tranny and rearend swap)? thanks
Old Mar 3, 2005 | 06:03 PM
GTA matt's Avatar
Car: 1990 GTA/1989 Iroc
Engine: L98/383
Transmission: 700r4/t56 magnum
Axle/Gears: 9"
The 6.0 heads you are looking for come in the 2000 and up Chevy/GMC 2500's. Don't mess with the 99 and early 2000 heads. they are cast iron. Patriot performance remanufactures the 6.0 heads with updated parts as well.
Old Mar 5, 2005 | 02:20 AM
Crayz9000's Avatar
Engine: LB9 5.0L
davcamaro, you've got a PM with some answers. Hope they help.
Old Mar 5, 2005 | 11:19 AM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
GTAMATT,
I have a 99 silverado with a 5.3. They have the STOCK 082 ALUMINUM heads with a CI block.
Old Mar 5, 2005 | 06:36 PM
GTA matt's Avatar
Engine: L98/383
Axle/Gears: 9"
Originally posted by Bri3212
GTAMATT,
Yep, the 4.8's and 5.3's came with aluminum heads in 99. The 6.0's came with cast iron.
Old Mar 5, 2005 | 10:38 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
I didnt know they had the 6.0's in 99'. I thought all that was availible was the:
262ci 4.3l
294ci 4.8l
325ci 5.3l
I thought the 362ci 6.0l came out on 00' model Denali's.
Old Mar 6, 2005 | 06:29 AM
GTA matt's Avatar
Engine: L98/383
Axle/Gears: 9"
262ci 4.3l
294ci 4.8l
325ci 5.3l
In late 99 they came out with the updated 2500 with the 6.0. They switched to aluminum heads mid to late 2000. The really good 6.0 heads are on the Escalades though.
gta90
Sep 15, 2015 04:00 PM
theurge
Aug 21, 2015 12:46 PM
86White_T/A305
Aug 17, 2015 12:16 AM
ZONES89RS
South Central
Aug 14, 2015 09:07 PM
