Valve springs.
Seat pressure should be at least 120 psi, and is dictated by installed height. Measure cam lift and rocker ratio to find valve lift and then compare this to coil bind height and installed height. A good number to shoot for 100 thou coil bind clearance. When assembling your head try to match the weakest springs with the shortest valves to balance the valve train.
'87 Bird 350 .060 over 700R4 + Lots more
355tpipickup
Sep 13, 2015 11:35 PM
Springster
Sep 13, 2015 01:38 PM
