Jump started another car, cooling fans won't work now!
Old Jul 10, 2001 | 09:29 AM
Allan's Avatar
Car: 1988 IROC-Z
Engine: 5.7L TPI
Axle/Gears: BW 2.77
I helped out a friend with a dead battery and jump started his car. I noticed right after that, that I was overheating! Found out, now my cooling fans won't kick on. They were working fine just before that. With A/C on and my temp switch override switch on, neither fan will come on (dual fan set up).
I have checked fuses under dashboard and the fuse by the fan relays and all are good. Any ideas what would cause neither fan to work all of a sudden? Is there a common ground to look for that may have "burnt up" during the jump?
I can't see jump starting another car doing this, but anything can happen.
Old Jul 10, 2001 | 02:10 PM
Jester's Avatar
Were you drunk when you did this my any chance
If it's not a fuse, then the relay is the next most likely culprit. I'd bum ya one of mine..but it's fused They're cheap at Discount tho..
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
Old Jul 10, 2001 | 05:32 PM
Allan's Avatar
Car: 1988 IROC-Z
Engine: 5.7L TPI
Axle/Gears: BW 2.77
<font face="Verdana, Arial" size="2">Originally posted by Jester:
</font>
Uh, no.
I may go ahead and try the relays. I mean, it's rare that both blow at the same time, but like I said, anything's possible. I'm looking to more of a common between the two since they are separate circuits, one for the A/C and the other for water temp.
Old Jul 10, 2001 | 07:27 PM
Allan's Avatar
Car: 1988 IROC-Z
Engine: 5.7L TPI
Axle/Gears: BW 2.77
Nevermind, fixed it. Apparently, there is a common connector by the battery. Reseated it and they now work. I swore I did that when it overheated, but what the hell. It works. Nuf said.
1992rs/ss
Jan 31, 2025 05:10 PM
TheExaminer
Aug 26, 2015 04:59 PM
86Base
Aug 8, 2015 01:34 PM
Leggman1
Aug 6, 2015 04:15 AM
