What should I gap them at with Msd??
Old Mar 5, 2005 | 01:40 AM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
Hey guys I have an MSD 6AL box, blaster 3 coil, and a pro-billet msd dist. I run them on a vortec headed motor with r44lts plugs. what would be a good gap for these?? I was running a .045 but i don;t think its right.. thanks guys.
Old Mar 5, 2005 | 05:36 AM
ede's Avatar
ede
.045 would be good, or a good place to start
Old Mar 5, 2005 | 06:22 PM
Damon's Avatar
Agreed, .045 will work fine. You can probably open them up some, depending on how much compression you are running in the motor.
If you're running boost or nitrous that all goes out the window and I gap them down under .040 even if your ignition is fortified with Vitamin MSD.
Old Mar 6, 2005 | 07:01 PM
Nathan Plemons's Avatar
Car: 1992 Chevrolet Corvette
Transmission: ZF-6
I run the R44LTS plugs in my LT1, which in my case should still be seeing around 10.5:1 compression. I've got an MSD digital 6 with the GM blaster coil for late model (the direct LT1 replacement coil from MSD) I have no trouble running a gap of .060.
I have read though that the gap between the rotor and contacts in the opti is actually tighter than a typical distributor though so you might have to back it off some. I'd certainly close the gap some if you're running nitrous.
Old Mar 7, 2005 | 01:37 AM
Car: 89 Formula
Engine: Carbed 5.7
hmm smaller gap for nitrous you say, thats the first I have heard of that, Would .35 be to small with the nitrous?? I plan on getting the Edelbrock performer kit and keeping it to a 50-75 shot max, I don't want to hurt the motor at all.. Thanks guys
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
sreZ28
Oct 22, 2015 08:21 AM
meeklay812
Oct 1, 2015 03:46 PM
86CamaroDan
Sep 29, 2015 10:08 PM
