1984 - Electro-Mechanical Fuel Delivery?
Old Mar 6, 2005 | 12:11 PM
z28cmr83's Avatar
Car: 83 Z28, 84 Z28
Engine: 5.0 Cross Fire, 5.0 H.O.
Transmission: 4 Speed Auto, 5 Speed Manual
My 84 camaro has a spot in the fues box for an electric fuel pump fuse, there is no fuse in there. I know my 83 Crossfire has an electric one in the tank, does my 84 have a mechanical and an electric?
Old Mar 6, 2005 | 01:53 PM
Vader's Avatar
Usually, it's an either / or thing.
Old Mar 6, 2005 | 06:35 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Didn't a couple Z28's have an electric in the tank and a mechanical up front? I coulda sworn I heard that somewhere...
But most likely, it was just GM re-using the fuse box.
Old Mar 6, 2005 | 06:41 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Your 83 should have just the mechanical pump. AFAIK, GM didn't start the joint pump operation (mechanical primary pump and electrical in-tank helper) in 86, to help alleviate the issue of vapor lock.
Old Mar 6, 2005 | 07:17 PM
z28cmr83's Avatar
Car: 83 Z28, 84 Z28
my 83 CFI only has an electric.
my 84 carbed has a mechanical with a Fuel Pump fuse.
I figure it is just GM reusing the fuse box, but i did hear of an electro-mechanical fuel system on these cars, so i figured mabe all this time i could have been takin advantage of 2 pumps and the previous owner just never put the fuse in the box.
Old Mar 6, 2005 | 11:08 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
GM is cheap when it comes to design, one fuse box fits all which isnt really a cheap thing but more of a cost effective solution. My 82 even has a spot for the fuse.
My 84 Z28 does have an intank pump so it may have been serviced for the vapor lock problem or came with it from the factory. I do know it wont do the job by itself but at least it gave me a nice wire harness to tap into for the rotary pump.
jhawkeye
May 25, 2022 06:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
Infested
May 22, 2018 11:56 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
suzuki949
Aug 28, 2015 08:07 AM
