Car dies when hot
Old Jul 10, 2001 | 09:49 AM
bozjr's Avatar
Car dies when hot
I have an 84 z-28 with the LG4 engine, 5 speed trans. It has a 4 barrell carb. (I think they all do) Sometimes, when its hot and I've been driving it alot, it will act sluggish and stall. It won't start right away, but if I leave it alone for about 20 minutes it will start and drive just fine. The guy who had the car before me replaced the fuel pump with an electic one. Could it be vapor lock? If so, what should I do?
Old Jul 10, 2001 | 05:02 PM
rondubbs's Avatar
check the ignition system,,
sounds like the pickup coil and/or ignition module
Old Jul 12, 2001 | 10:25 AM
sb406camaro86's Avatar
Car: chevy s10,1986camaro
Engine: 406sbc
Transmission: 350turbo
had a similar prob with my car but i have a mech fuel pump. Turned out my fuel line was run too close to the block and head, so the fuel was boiling in the fuel bowels.
I discovered this one day when i pulled over to show some dude my engine. When i pulled of the air cleaner i could see the fuel steaming and bubbling out the fuel bowl vents.
Old Jul 12, 2001 | 11:09 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
I had the same exact problem....turned out that a rubber hose leading into the fuel pump from the tank had a tear in it. The pump worked but because of the hole in the hose no fuel was able to get through. The problem only occurred when the engine was hot because the heat expanded the hole. When it was cold the hole didn't cause any problems.
Hope this helps
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Z28 Grille w/aftmkt fog lamps, MacEwen white-face guages
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, 3.42 gears w/Torsen posi
Old Jul 12, 2001 | 02:55 PM
bozjr's Avatar
Thanks for the replies I think that my fuel line is run to close to my engine block. Should I reroute the line, or try to insulate it?
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
86Base
Aug 8, 2015 01:34 PM
