Need Cam Selection Help?
Old Mar 8, 2005 | 09:22 PM
89blackm's Avatar
I have recently done work on a 350 and i need to know which type of cam i should run for the best performace.Its a 1975 350 4bolt main bored .060 over,set of Dart 215cc 23degree aluminum heads which flow in the upper 290cfm, spring,valves,caps keepers have been upgraded,air gap intake,and a 750 holley Double Pumper. A 700r4 raptor tranny with 2600/2800 stall and 3:42 posi rear
Old Mar 8, 2005 | 09:55 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
You still need to say if it will be a daily driver or weekend car or monthly car. Will it see a lot of dragstrip?
Old Mar 8, 2005 | 10:04 PM
89blackm's Avatar
Its a daily driver.From my house to school and back home(about 6 miles)Then to work which is about 5 from my house and then of course the cruising with friends on friday and saturday nights.it will occasionally be on the strip about once or twice a week.
Old Mar 8, 2005 | 10:10 PM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
I say get a cam with duration in the 230 range and with as much lift as you can.
Comp xe 274 hr
224 I
230 E
Old Mar 8, 2005 | 10:13 PM
89blackm's Avatar
Any particular brand or any of the top ones will do?
Jorlain
Oct 8, 2015 01:57 AM
1Aauto
Sponsored Vendors
Oct 5, 2015 03:14 PM
1Aauto
Sponsored Vendors
Oct 5, 2015 03:13 PM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
