2.8 flooding
Old Mar 9, 2005 | 04:25 PM
pudhead's Avatar
Car: 85 Firebird
Engine: 2.8
Transmission: automatic
2.8 flooding
I have a 1985 Firebird 2.8, it floods terrible and won't stay running, it is showing no codes. I have changed plugs, wires, coil, cap and rotor. Also o rings on the injectors, fuel pressure is in range. I can unplug the mass air flow and the car runs alot better with limited flooding but sounds as if the engine is smothering with no power. Any help you all can give me will be greatly appreciated.
Old Mar 10, 2005 | 02:41 PM
sellmanb's Avatar
Car: '86 Berlinetta
take your MAF into the parts store and have them check it. It's probably faulty.
Old Mar 13, 2005 | 07:00 AM
pudhead's Avatar
Car: 85 Firebird
Engine: 2.8
Thanks so much I was the MAF Sensor. Can't thank you enough.
Old Mar 13, 2005 | 01:02 PM
sellmanb's Avatar
Car: '86 Berlinetta
no problem. The fact that it ran well in limp home mode w/ the MAF off was a tell-tale sign that it was faulty.
Thanks for replying to tell us all what the fix was. You'll find there's nothing more annoying than searching through posts to find one with your same symptoms, and at the end, the person does not post what his fix was!
86maro_252
Oct 10, 2015 06:52 PM
Zane Story
Oct 8, 2015 12:40 PM
usafirebird
Sep 29, 2015 11:58 PM
spartanreaper
Sep 25, 2015 07:22 PM
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
