Pulled codes 42 and 12...who wants to help?
Old Jul 14, 2001 | 04:27 PM
1991camaroRS's Avatar
I know this should probably be in some other section but i figured i'd get a quicker response here...anyway, i recently got my check engine light and i went to pull the codes and i got 12 (No reference pulses to electronic control mudule) and 42 (Fault at electronic spark timing circuit;fault at direct ignition system OR fault at fuel cutoff relay circuit)...what the hell do these mean? I'd appreciate quick help, thanx for any help u guys can give me
1991 Camaro RS (Red)
-TTops
-Custom quad exhaust
-Edelbrock 14x3 open air element
Old Jul 14, 2001 | 04:41 PM
92blackbird's Avatar
Car: 1992 pontiac firebird
Engine: 305 tbi
the 42 code or est is an electronic spark control it controls the ignition spark advance. on my 92 there is a black and tan wire with a single connector. if the timing is changed this must be disconnected then reconnected after the timing is set and the engine shut off. if someone reset your timing and didn't hook this back up it will give a 42 code. the 12 code shows every tiime you bridge the A and B diagnostic posts to check for codes. there's a ECM disconnect plug on the passenger side close to the + battery terminal. you can either disconnect that or the + battery cable to clear the codes.
'92 firebird t-tops
305tbi,670cfm tbi, 2 1/2" Dynomax catback, 9x3 K&N open element
Old Jul 14, 2001 | 04:46 PM
Engine: 305 tbi
forgot to tell you the est wire is on the passenger side. mine is near the washer resovoir
'92 firebird t-tops
Allan's Avatar
Car: 1988 IROC-Z
Engine: 5.7L TPI
Axle/Gears: BW 2.77
<font face="Verdana, Arial" size="2">Originally posted by 92blackbird:
</font>
Agreed. Every time you disconnect the EST BP wire to set timing and don't short the A and B terminals of the ALDL, you'll get code 42 stored. Disconnect the battery for 30 seconds to a minute to clear the codes and check again. You should just get 12.
Next time you set timing, disconnect the wire AND short A and B on the ALDL. Those are the proper procedures in setting time.
[This message has been edited by Allan (edited July 14, 2001).]
Old Jul 14, 2001 | 04:58 PM
Hmm, very interesting except for the fact that no one has touched my timing since i've had the car which is why i'm perplexed as to why i'm getting a 42 all of a sudden. I'll try resetting the computer again and see what happends, gracias for the quick responses.
-TTops
-Edelbrock 14x3 open air element w/ K&N filter
*Coming Soon*
Cowl Induction hood
Old Jul 14, 2001 | 06:18 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
I have had this problem with my new buildup. You can go to Autozone and tell them you need a code 42 check off sheet and it will give you steps to go through........I will tell you it can come back to a bad Dist controll module, Pickup coil or Ecm
Brian
1989 Camaro RS
305 .030 over Hydro Pistons
Vortech heads milled to 58cc...Performer RPM intake....LT4 cam..Crane Gold rockers...FastChip custom chip...ALum. Driveshaft...3.73 gears with Posi...underdrive pullys...Rebuilt 700R4 with Vette Servo and B&M shift Kit...MSD ignition...A/C Delete No SMOG junk....1997 SS leather interior...B&M Shifter... Ultimate TBI mods...14X3 K&N open Element Non-Drop...Hooker headers....3" exhaust with Flowmaster Cross flow 16X8 Wheels from 97 RS Spohn LCA's Spohn Panhard Bar..LETS PLAY FORD!!
www.geocities.com/feltsb
chazman
Aug 28, 2018 03:25 PM
86IROC112
Aug 31, 2015 07:00 AM
chazman
Aug 22, 2015 02:01 PM
GouldyGTR
Aug 21, 2015 10:43 PM
