what compression am i running?
Old Mar 12, 2005 | 04:02 PM
355tpipickup's Avatar
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
hi i had a 91 tpi motor from a z28 put in my 92 2wd chevy truck, the motor is .40 over with flat top hypereutectic pistons, im running the stock cast iron heads, i want to know what my compression is because im looking for some afrs and i would like to have around a 10:1 or so.
Old Mar 12, 2005 | 04:04 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
To many variables that need to be either known or measured.
I'd guess around 9:1 -8.5:1 though.
Old Mar 12, 2005 | 04:18 PM
Car: 92 1500p\u 2wd
what variables do u need to know, maby i can help or find out? is there anyway i can test my cilinder pres and then figure out the comp.? that may have been a stupid question, but i dont know much about compression and heads. im guessing that since the heads are stock that the gaskets are the stock thikness and deck height is the same and all that,
Old Mar 12, 2005 | 04:46 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
What pistons do you have? What is the deck height? If the engine has been bored .040" over, I doubt you have factory head gaskets.
Can't really turn cylinder PSI into a ratio.
Old Mar 12, 2005 | 07:00 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
The only accurate way to determine the compression ratio of your motor is to remove the cylinder heads and
*measure the piston deck clearance @TDC
*measure or determine the piston dish or valve relief volume.
*measure the cylinder head combustion chamber volume
*Measure or determine the head gasket volume. (crushed)
Then you can input these variables into a online calc like
This One
Anything else is just a guess.
My guess is, it's between 9.3 and 9.8:1
customblackbird
Aug 15, 2021 10:16 PM
theshackle
Mar 5, 2017 06:37 PM
NWAsonoma
Aug 18, 2015 05:45 PM
355tpipickup
Aug 13, 2015 07:35 AM
BBSDesigns
Aug 11, 2015 07:39 PM
