Is this distributor going to fit in the firewall???
Old Mar 13, 2005 | 06:15 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
I am really worried, after looking at how friggin huge it is on the manifold. It's about 1" lower than the carb, on an air-gap intake. It's a coil-in-cap dizzy, also. I hope I hope I hope it fits!
I don't have the stock one handy to compare.
Attached Thumbnails Is this distributor going to fit in the firewall???-c-stuff-yaymoreparts2.jpg
Old Mar 13, 2005 | 06:18 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWN%3AIT
thats what I bought
Old Mar 13, 2005 | 06:22 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
It's close, but it fits.
Old Mar 13, 2005 | 06:23 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
phew, alright, I was thinking and I began to panic. I've got the pre-engine-swap jitters.
Old Mar 13, 2005 | 06:25 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Nothing to worry about, that unit was stock on some cars.
Old Mar 13, 2005 | 06:26 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Perfect!
Old Mar 13, 2005 | 06:53 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
With the engine in the stock location, the large cap HEI will fit. I even used one with my BBC. I have to use a small MSD distributor now because of the tunnel ram and the engine has been moved back
Old Mar 13, 2005 | 11:00 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
It will fit just fine. I have almost the exact set up as you. Vortec heads w/air gap manifold. I will be using a 454 tbi to run the engine. If it does not work, I will be using my backup...carb.
Old Mar 14, 2005 | 06:43 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Doesn't matter what kind of manifold you use; the dist ends up in the same place. It still has to mesh with the dist gear and fit in the block and drive the oil pump.
Duh.
That dist was stock for these cars from 82 to 86. It will fit fine. Not even close to interfering with the firewall.
Old Mar 14, 2005 | 11:54 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
That is a close call but it does fit.
Just remember to remove that thing if you ever pull the trans or yank the motor. The motor will rock back and jam it into the fire wall. Not good.
Why I prefer to just install the distributor in the front of the motor.
Much easier to work on and it doesn't get in the way. You can set the motor back some too. Its becoming a popular mod. Did it to my wagon.
$150-$300 mod depending on your connections.
Old Mar 14, 2005 | 02:45 PM
sellmanb's Avatar
Car: '86 Berlinetta
Silly Token, you should know better than to start thinking J/k man
Looks like your new engine is coming together pretty fast! How's the whole assembling the motor in the back of your Buick going for yah now? Still manageable?
Curious how you plan to put the motor into the car once you have it assembled though hehe.
Old Mar 14, 2005 | 03:15 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
If that were my distributor, I know it wouldn't fit unless I got a NON-DROP air cleaner/element. What kind of air cleaner is on the new engine?
Old Mar 14, 2005 | 04:09 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
lol the motor is already assembled, I'm just waiting for nice weather.
I dont know abut an air cleaner, but I probably should get one.
Frozer!!!
Jan 19, 2024 04:55 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
stalkier
Dec 6, 2015 11:25 PM
fbirdroller
Sep 2, 2015 10:27 PM
86IROC112
Aug 17, 2015 07:57 PM
