What is required for a higher reving engine?
Old Jul 12, 2001 | 09:29 PM
camaroguy99's Avatar
I'm building up a L98 and I was wondering what I can do to get the engine to rev up to like 6000 without it trying to tear itself apart?
Jim
Old Jul 12, 2001 | 09:39 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Any engine can rev to 6000. Only the cam will determine if it's worth going that high. The powerband of the camshaft is what determines how high an engine has to rev.
Once you know how high the engine has to rev, then you determine what other parts are required. Valve springs, rod bolts, torque converter etc.
You'll have to change the induction system. A L98 TPI system won't flow enough air for a 6000 rpm engine.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
[This message has been edited by Stephen 87 IROC (edited July 12, 2001).]
Old Jul 12, 2001 | 09:50 PM
Sorry, I should have listed the stuff I have now:
compcams xtreame energy cam w/ following specs 230/236 duration @.05", gross valve lift: .480/.490, and a LSA of 110.
compcams springs, lifters, and hardend pushrods.
TCI break away converter w/stall speed 1000 above stock.
As far as the intake goes:
AS&M SSLTR
Ported plenum
52mm TB
TPIS base port matched
ported stock heads
thanks again
Old Jul 13, 2001 | 04:18 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
You should be making power upto 6,200 RPM and require the higher stall cam. The stock TPI is choking everything. Either get a miniram or some SLP runners and start porting. A 52mm throttle body helps. Check out what madmax did with his intake. That should support the air requirements no prob... Also better heads would really help... or a good pocket port and 3 angle.
What rear gears you running?
Old Jul 13, 2001 | 12:13 PM
Z28Man's Avatar
All it takes is MONEY
Old Jul 13, 2001 | 02:29 PM
I'm running 3.23 gears. As far as the intake goes I think it should breathe pretty well, the only possible restriction that I can see would be the heads.
Joel,
what did you mean by requiring a higher stall cam? did you mean torque converter?
With regards to the madmax porting job. I would do that with a stock base but I really don't want to mess with a $500 intake base. I;m too scared of f'ing it up.
what I was worried about is reving to high and damaging the engine. I put my friends 91 z up to about 6000 and it sounded like it was going to tear itself apart . That had to be the worst sound I have ever heard. I have dumped alot of money into this engine so far and I really don't want to do that to mine.
thanks again
Jim
[This message has been edited by camaroguy99 (edited July 13, 2001).]
Old Jul 13, 2001 | 09:13 PM
ttt
Old Jul 15, 2001 | 01:22 AM
so do you guys think this engine will stand up to making runs near 6000 or 6500 RMS's?
Old Jul 15, 2001 | 02:40 PM
JoelOl75's Avatar
My bad, yeah I meant torque converter...
With a little work on a stock TPI ditching the stock runners, 6000 isn't unrealistic. I shift @ a hair over 6,000.
junkcltr
Aug 2, 2019 11:12 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
