Spark change in aluminum heads what should I whach for?
Old Apr 25, 2001 | 09:14 PM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
I am changing the plugs in my 96 z24 and it has a aluminum head, the plugs are the platinum plugs and even though they are not supose to be changed for another 50,000, I think I will change anyway. So what should I do? is there anything to becarfull about?thanks
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Old Apr 26, 2001 | 04:32 AM
ColinOpseth's Avatar
Car: 1987 Camaro IROC-Z
Engine: 305TPI
yes, be careful.
do NOT overtighten your plugs.
spend the extra 15 minutes and use a torque wrench and torque them correctly (can't remember torque off hand, look in your Chilton's)
YOU HAVE TO USE ANTI-SIEZE ON THE THREADS. do NOT forget this!
again, do NOT overtorque or forget to use anti-sieze or you will risk pulling out your threads next time you change your plugs either from the threads being damaged or being affected from the plugs siezing in the threads
Webmaster: www.IROC-Z.org
Old Apr 29, 2001 | 01:50 AM
BLACK Z's Avatar
Car: 86 Z28
I don't have a torque wrench, could I get away with out it? Will regular anti seize work? thanks
Old Apr 29, 2001 | 08:05 AM
ede's Avatar
ede
you don't have to use a torque wrench, but it's good insurance agains over tightening. i usually don't use one and have never stripped a thread, but i have a pretty good idea what it should feel like when the plug is tight. use anti seive, any kind will work.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Apr 29, 2001 | 01:27 PM
Fimbulvetr's Avatar
Alot of place will rent torque wrenches, little on the spendy side, but Id rather rent one of them than pay for new heads
Old Jul 14, 2001 | 11:59 PM
BLACK Z's Avatar
Car: 86 Z28
btt
Old Jul 15, 2001 | 12:21 AM
iroc5speed's Avatar
torque wrenches don't cost that much to buy anyways, why rent one? I bought a good one for $25 at advance auto.
Old Jul 15, 2001 | 02:46 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
Make sure the engine is stone cold before you remove the old plugs.
eightsixseven
Dec 16, 2024 01:50 PM
midge54
Dec 27, 2019 04:14 PM
evilstuie
Feb 28, 2016 03:33 PM
92camaroJoe
Aug 13, 2015 06:07 AM
