Oil Pressure - Eratic!
Old Mar 14, 2005 | 08:56 PM
InsaneContender's Avatar
Car: '92 Camaro RS
Engine: V8 5.0L
Transmission: Automatic
I just recently changed my oil, thinking that it would solve this problem - but it didnt.
My oil pressure is rather erratic - when I first start up, pressure is normal. Within the 20-35 range. Then, after maybe 15 miles of driving - or 15-20 minutes of driving - whenever I come to a stop - the pressure will drop to zero and the engine will sort of "studder"
It's rather odd. I'm not sure what it is... anyone?
Old Mar 15, 2005 | 03:50 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Probably the oil pressure sending unit. Best way to verify that is to hook up a mechanical gage, either temporarily, or permanently.
Old Mar 15, 2005 | 03:54 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
my car did exactly this for about a month... until it started to make a knocking sound. I spun a bearing.
Old Mar 15, 2005 | 06:19 PM
five7kid's Avatar
Then again, it may really be low oil pressure, in which case you may start wiping out bearings...
Old Mar 15, 2005 | 08:59 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Verify the oil pressure with a mechanical gauge and work from there.
Generally, for me, if the oil pressure drops and is accompanied with a sudden ill-acting engine, something is "not right."
83 Crossfire TA
Jan 3, 2016 01:26 PM
angel2794
Sep 8, 2015 06:22 PM
Strick1
Sep 4, 2015 07:11 AM
solocus
Sep 2, 2015 12:14 PM
