Will this bottom end handle this combo?
Old Mar 15, 2005 | 05:15 PM
Rogue86's Avatar
Car: 94 Camaro
Engine: 380 sbc
Transmission: th400
Axle/Gears: 9" 4.11
After some debate, I've decided to rebuild and beef up my motor. This is what I'm looking at for a bottom end
-'79 4 bolt main 350 .060 over Align honed, 0 decked, and all the fixins'
-Stock Crank, Stock rods with arp bolts, Flat top forged speed pro pistons.
-Balanced Rotating assembly.
Eventually I want to put this trick flow top-end kit on it, or make equal power. Trick Flow top end
edit: that url only gets you to summit racing. The part number is TFS-K314-490-440
490hp 440 ft lbs
Old Mar 15, 2005 | 05:43 PM
92heritageRS's Avatar
Car: 06 Trailblazer SS
Engine: 6.0 LS2
Axle/Gears: 4.10
P/N TFS-K314-500-450. I would use this on your short block and have fun. But remember what you have before you go bracket racing every friday with it. For the street I would do it. For racing/nitrous abuse I would do the whole forged crank and upgraded rods. You do have forged pistons. Thats a plus! Good luck!
Old Mar 15, 2005 | 05:44 PM
Engine: 6.0 LS2
Axle/Gears: 4.10
TFS-K314-490-440 is a good one too
Old Mar 15, 2005 | 05:49 PM
Rogue86's Avatar
Car: 94 Camaro
Engine: 380 sbc
Transmission: th400
Axle/Gears: 9" 4.11
alright, actually i was looking at the 490 hp kit, but there would be no nitrous invovled anywhere
I know a member on here is pushing his 383 pretty hard on stock rods and crank. Enough to get the 3400lb car into the 10's anyways.
Old Mar 15, 2005 | 05:57 PM
Engine: 6.0 LS2
Axle/Gears: 4.10
Yes it will handle it.
Old Mar 15, 2005 | 06:34 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Power in itself does not kill the bottom end.
Detonation, spark scatter, exessive rpm, loss of oil flow will.
Get a rev limiter and use the required octane fuel and don;t worry about it.
Old Mar 15, 2005 | 07:03 PM
Rogue86's Avatar
Car: 94 Camaro
Engine: 380 sbc
Transmission: th400
Axle/Gears: 9" 4.11
All should be good with compression/fuel. Flat tops and 72cc heads should make for premium friendly driving.
Old Mar 15, 2005 | 07:38 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
stock 400 bottom ends are junk...i wouldnt spin it over 5,500 rpms unless i missed a shift...let alone 500 ponies
Old Mar 15, 2005 | 09:01 PM
Rogue86's Avatar
Car: 94 Camaro
Engine: 380 sbc
Transmission: th400
Axle/Gears: 9" 4.11
well I have a 350... so doesn't really apply to me to much. I've already spun it out to 6000 on 150+ passes down the track, and it accidentilly saw 6500 once. All is still good. When the trick flow kit goes in I plan to spin it to 6800 or so probably.
Better not tell that part about 5000 rpms to IHI I know he drives that car a ton, and it seems to survive quite well.
theshackle
Mar 5, 2017 06:37 PM
beastin91rs
Oct 9, 2015 07:38 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
86IROC112
Aug 21, 2015 07:20 PM
