Vortec Head ?
Old Mar 14, 2005 | 11:01 PM
gen3-4's Avatar
Vortec Head ?
WHAT IS A THE MOST CAM LIFT THAT WILL NOT PULL OUT MY VORTEC HEAD ROCKER ARMS STUDS CASTING #060 ON A 350 ENGINE.
Old Mar 15, 2005 | 09:07 AM
dyeager535's Avatar
Car: Which one?
Engine: 355
Transmission: 465
I know very little about what it takes to pull the studs out, but I do know with my vortecs that .452" lift was as much as I could run without cutting the valve guides down.
On top of that, if you are talking radical cam, you will need to replace the springs, which also requires cutting, or expensive beehive springs.
Old Mar 15, 2005 | 05:00 PM
gen3-4's Avatar
thanks four help, my heads just can in from summit not 060 heads their 062 belive to be truck heads i read their better.
Old Mar 15, 2005 | 06:16 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
It's not really a function of cam lift or valve lift as to wether the studs pull out. More to do with spring pressure and rpm.
Why not just drill and pin the studs so you don't have to worry about it.
The stock L-31 vortec heads as machined by GM definatily have a limited valve lift compatability. If you plan on installing a cam with more than .450" lift you should check and verify retainer bottom to guide boss/seal top clearance and machine down the top of the guide boss if nessessary.
(or yu definiatly be pul;ling the studs and bending pushrods etc.)
Vortec heads work very well but do need the extra valvetrain
preperation to get them ready for high performance use.
All part of the joys.
84z96L31vortec
Aug 20, 2017 12:16 AM
Tinbender59
Mar 17, 2017 10:50 AM
z28guy134
Sep 1, 2015 11:50 PM
earlpote
Aug 28, 2015 10:42 AM
L98GTA87
Aug 11, 2015 06:55 PM
