Several unrelated questions
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
First headers: I had mine jetcoated and they are about to be sent to me, my friend who has a 92 Z28 heard that headers get very hot ie red hot and I was wondering if this is true and also if the jethot coating makes them stay a little cooler.
Second springs, I think I know the answer, but just so I don't do something stupid, the long thin springs are for the front and the shorter thick springs are the back ones right? note: they are eibachs
last and least, just out of curiousity is my seatbelt supposed to tighten and lock when I accelerate hard? Because it does, noticeable so as though it is anticipating me hitting something, I know of ones that lock when braking hard, but never accelerating is this how they are supposed to be?
Flowmaster,Edelbrock open filliment filter with K&N filter in it
160 stat, BF G-Force w-rated tires
Location: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
1- Coated headers keep the heat from the engine inside the pipes, thus keeping the bay slightly cooler. Headers shouldn't become red-hot....that may be a sign of very bad timing(retarded too much)...but I'm not sure.
2- Not sure about this, but generally the lower stance is seen at the front of the car...shorter springs on the front.
3- Yes, the seatbelt will lock down on you when you accelerate hard.
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Z28 Grille w/aftmkt fog lamps, MacEwen white-face guages
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, 3.42 gears w/Torsen posi
Performance:
Electronics:
Car: 92' RS
Engine: LO3
Oh man the short thick ones go in front?
not to doubt anyone I just thought the larger ones went in front, hmm they probly ment larger in the thickness sense i guess, well that would have been bad, glad I asked.
1: supposedly, the coatings help keep things cooler.
2: fat ones in front, but you would have found that out as soon as you took the old ones out.
3: the seatbelts should lock whenever there is signifigant g-forces (usually on braking, sometimes on acceleration, and sometimes on hard cornering). it has what's called an intertia-ball or inertia-lock inside it that locks the reel.
