Cam Selection
Old Mar 15, 2005 | 03:37 PM
89blackm's Avatar
Cam Selection
I need some opinions for a cam.I have a '75 flat tappet 350 bored .060 over,airgap intake,750holley dp, 215cc ported and polished dart heads, true duals with long tube headers,built 700r4 tranny with a stall from 2600-3200, 3:42 gears......This car will be doing it all. Daily driver,racing now and then, cruising down the freeway. So id like a few suggestions on what you would use and what brand. thanks
Old Mar 15, 2005 | 06:20 PM
92heritageRS's Avatar
Car: 06 Trailblazer SS
Engine: 6.0 LS2
Axle/Gears: 4.10
Most members of this site that still have flat tap cams swear by the Comp XE 274
Old Mar 15, 2005 | 09:24 PM
89blackm's Avatar
Anyone else back that up?
Old Mar 20, 2005 | 09:31 PM
89blackm's Avatar
Would anybody consider something else???Otherwise im probably going with the suggested one.
Old Apr 3, 2005 | 12:18 PM
Karnage214's Avatar
Car: 1992 Firebird Formula
Engine: soon to be 383
Transmission: 700R4 w/2800 stall
With your setup it sounds like you might be better off with a slighty larger cam, if your gonna use a solid flat tappet, id probably go with comp cams XS282S or 294S. If your gonna use hydraulic flat tappet, maybe 292H or XE284H.
Old Apr 3, 2005 | 03:38 PM
IROC4LIFE's Avatar
Car: 1986 IROC-Z
Engine: SBC
Transmission: Manual Th-350
Axle/Gears: 9" Moser 3.89's Spool.
Im having this debate right now,
Motor is 11:1-1 Compression 355 with 6.0inch rods, Vic Jr intake, Pro Mag 1.5's, AFR195's 68cc heads with std porting.
Trying to Decide on either a XS282S or Magnum 294s.
Old Apr 3, 2005 | 04:48 PM
89blackm's Avatar
the xe274 and lifters are order as of friday
Jorlain
Oct 8, 2015 01:57 AM
1Aauto
Sponsored Vendors
Oct 5, 2015 03:14 PM
1Aauto
Sponsored Vendors
Oct 5, 2015 03:13 PM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
