spark plug gap on 383
Old Mar 16, 2005 | 12:51 PM
virtigo8776's Avatar
Car: 85 trans am
Engine: 383
Transmission: 700
just a general question. usually gap my plugs at .60. have heard some gap them at .45 for 383s. just wondering if eiter gap is better or makes a difference
Old Mar 16, 2005 | 01:06 PM
92MaroRS's Avatar
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
The longer the gap the hotter the spark, but takes a tremendous amout of voltage so you need a coil that can jump the gap. run the largest gap you can jump without predetenation.
Old Mar 16, 2005 | 02:07 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
The AC Delco Rapid Fire plugs I run come gapped @ .045". I regapped them to .038" on my 388 after I was sure it wasn't detonating (10:1CR fast burn alum heads.)
Plug gapping
another site
evilstuie
Feb 28, 2016 03:33 PM
LittleFranks
Sep 17, 2015 12:22 PM
tricky1
Aug 23, 2015 01:17 PM
g.l.mos
Aug 22, 2015 12:02 AM
