'88 5.7 Negative Battery Cable Ground
Old Mar 16, 2005 | 04:37 PM
PRoth's Avatar
All:
Where does the negative battery cable connect to on the serpentine belt bracket on 305/350's? (Yes, I know one end goes to the battery)
I'm trying to put a car back together, and have no clue as to where the neg cable goes.
Thanks,
-P
Old Mar 16, 2005 | 04:39 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
It doesn't matter where you put it, but its best to attach it directly to the block.
Old Mar 16, 2005 | 05:06 PM
PRoth's Avatar
I'd rather use the factory spot if possible.
-P
Old Mar 16, 2005 | 07:58 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
it goes to the bottom bolt hole (on my car it was the drivers side) under the p/s pump side the closest hole to the road (there are two one above the other)
Old Mar 16, 2005 | 08:06 PM
PRoth's Avatar
I guess Camaro's are different then, as the battery is on the passenger side. So there's got to be someplace else.
Old Mar 19, 2005 | 12:24 PM
Engine: ls1, LB9
same spot pass side then.
they have been using those spots for years
IROCtometal
Sep 20, 2015 11:08 PM
TheTraut88
Sep 11, 2015 05:16 AM
IROCtometal
Sep 9, 2015 10:01 AM
TheTraut88
Sep 7, 2015 05:22 PM
IROCtometal
Sep 2, 2015 02:01 PM
